Brake Issue.
tomtom9119
Right. I've had a problem with the brakes staying engaged while I'm driving, making the wheel super hot and smokey (not great). I've taken the caliper off and sprayed up the rubber around the piston (no cracks or leaks) and greased up the pads too. I've started bleeding the system and thought it was done, so I turn my engine on and straight away the brake engages and won't disengage. I'm thinking now its not the caliper/piston but more of an issue with either the master cylinder or the brake vacuum (if there is one).
