I have a 2006 Grand Voyager 2.8 CRD. EML came on and the auto box was unable to change into 4th gear (drives fine lower gears) Just revving higher and higher in 3rd. Managed to limp it home and not moved since. Plugged in OBDII and fault p0891 transmission fault appeared - relay circuit high or always on ????
dmbeale
Hi
Has anyone dealt with this before ?
Thank you in advance
