I am not very mechanical, so if you can help please keep it simple for me.
The issue has gradually got worse, it start about a month ago.
I notice that when I started my Voyager up, on the dash all the gears had boxes around. This happened every now and again and I thought may be I had not fully engaged the column shift in to the correct gear.
Shortly after as I was driving in "D" it suddenly changed itself to "L" (the column shift was not moved) and then jumped back to "D" this has happened a number of times now .
I had the gear box oil & filter changed as I did not know when it was last done and thought it may help.
But gradually it has got worse to the extent that every time I start the Voyager all the Gears are always got boxes around when the car is in "P". I move through all the gears and when it is in "P", "N" (some time this clears it, but less so lately ) all the gears show boxes also sometimes "3" & "L" do as well.
As I have electric doors and boot, it means I can not open them while the ignition is on as it does not appear to know it is in park.
Can anyone help ?? or know what I can look at/ check before taking it to a garage ??
Carlby
HELP.....
Looking forward to any assistance you can offer
Carlby
11 answers to this question
