The battery light is on and i checked the alternator connections.
I can find a contact that is hanging loose a bit below the alternator, if this is the alternator wires, it only has 2 pins. The colours doesnt match the wiring diagram either…
The generator mounted has a contact with 3 pins. When i check for new/used alternators they all seem to have 3 pin?
have i found the right contact? It doesnt reach the alternator but maybe the harness is mounted wrong?
can you tell me what contacts you have on your alternators for voyager 2.8crd 2012?
Roger82
Hello!
I have bought a lancia Voyager 2012 2.8crd.
