I O D Fuse Drain
Karld77
Help I have a iod fuse drain. On my 2.5 crd grand voyager . The rear fog lights don't work and also the reversing lights don't work . And neither does the boot catch I have to use the key all the time and ideas would greatfuly received thank peeps .?
As to the reversing lights check out the switch on nearside of gearbox. To check if its the switch, bridge across the two wires with the ignition on and if they light up its the switch at fault. If they don't check fuses and wiring.
Second thoughts here check wiring connections in boot.
Edited by gordy
  • 2 weeks later...
Hi there. I had exactly the same problem on my 2007 Voyager a few years ago. If it wasnt used for a couple of days, a fully charged battery was completely dead. So annoying. It turned out to be one of the radio speakers. The guy at Pulse car audio said it was a common fault. He changed the front speakers for some Kenwood ones, and the problem went away!
