Battery Fade When On Acc Just Radio On ?
crispinchurch
is this right
sit at school waiting for them to come out in a bout a hour my battery will go flat with just radio on
i put amp meter between earth wire and battery
car locked 1.5 amp drain
car unlocked with key on acc  2 amp drain
radio on with dab box 5 amp
dvd 6 amp drain
should a battery drain 6 amp flat enough it will need a jump starter
  Quote
Yes unless the battery is in good nick. A battery only has one job, to start the car, once started an alternator runs all the stuff happily. The normal condition of the battery pulls 0.015 to 0.025, just fifteen to twenty five milliamperes, its going to pull 25mA just for the PCM clock etc even when nothing is on and it pulls till 15 minutes after park & alarm when the computers are then put to sleep.
