Abs Light Help
bazas
My 1999 3.3 grand voyager has failed its MOT and the main problem is the ABS light. I finally managed to find a guy that could read the codes and this is what he came up with
G sensor Implausible Signal
Pump Motor Circuit Failure
All speed sensors
He drove the car a short distance and gets a speed reading back from all sensors so he thinks the problem is the ABS ECU.
What do you guys think and is the ABC ECU easy to change?
This is all that is holding up a pass on my MOT.
Thanks Baz
