darkchild101 Posted February 17, 2016 Report Share Posted February 17, 2016 My switch is very loose. In fact i can pull out the key at any point in the cycle with no resistance at all. Any fix for this please? Quote Link to comment Share on other sites More sharing options...
0 bignev Posted February 17, 2016 Report Share Posted February 17, 2016 My 2002 has always been the same as that, had it just under 4 years.Quite useful to leave the radio on for the kids when filling up actually. Try an experiment, have it in neutral not park, switch it off, and try taking the key out then - mine won't bizarely. The key won't even turn to the actual off position! Quote Link to comment Share on other sites More sharing options...
0 crispinchurch Posted February 17, 2016 Report Share Posted February 17, 2016 thats better than mine about once a month the key will go in but not turn at all have to hit the lock and sometimes that dont work i get the air line out and put 8 bar of air in the lock to clean it out Quote Link to comment Share on other sites More sharing options...
0 darkchild101 Posted February 18, 2016 Author Report Share Posted February 18, 2016 My 2002 has always been the same as that, had it just under 4 years.Quite useful to leave the radio on for the kids when filling up actually. Try an experiment, have it in neutral not park, switch it off, and try taking the key out then - mine won't bizarely. The key won't even turn to the actual off position! Mine is a manual. I managed to remove the key while engine was running. Not good at all Quote Link to comment Share on other sites More sharing options...
0 bignev Posted February 18, 2016 Report Share Posted February 18, 2016 Oh mine will come out with it running, no problem!At least you could force a stall on the engine in a manual, mine would ahve to run oput of fuel. Quote Link to comment Share on other sites More sharing options...
darkchild101
