Rear Wiper Issue
jonspage
I've got a 2004 2.5 CRD LX Grand Voyager and the rear wiper has become erratic. On intermittent, it moves part way over the rear screen and stops without returning to the normal stop position. Flicking the intermittent switch on & off moves the wiper, but not for a full sweep and/or return.
On continuous, it works OK but again it won't return to the normal stop position when I turn it off. The only way I can get it back to it's 'normal stop' position is to flick the switch off just before it gets there.
The other day during the bad weather I had the wiper running continuously, but then it stopped after a while during mid sweep and wouldn't start again, regardless of the switch position. When I turned off the ignition and switched it on again, the wiper started to work.
Any ideas?
