Cambelt Replacement
Dazandtrace
21 answers to this question
Dana and Trace
Costs unknown, but ISTR Ed China quoted a save of £100 ash
Costs to you time / fingers / cam belt / water pump (get the right one (bravos have many variants :-( )
If you watch Discovery Channel and faithful ED China - NO..... but he has a hot house to do his jobs.
Comfortable mechanic in the outdoors? Rain??
You have to set up the ^ with the ^ should be set up spot on and covered in case of faulty line up ......
Personally - I would pay a few quid to a reputable back street man / or man in a service van, to do the job.
Regards
Peckish Penguin
I've done the cam belt 3 times on a voyager diesel including one time with the water pump (which was actually fine with 130K miles) it's a time consuming, but not too difficult job. You need a set of timing pins to lock the engine and cams in place, but other than that just normal tools.
Took me all day to do the belt and pump, about 5-6hrs to do just the belt...
  On 2/5/2016 at 12:43 PM, Dazandtrace said:
Hi well its that time of the cars life to have it's cambelt and waterpump replacement. Just booked in with my local indy garage for monday. Nice quote £420 all in.
Cv 2006 2.8 crd.
At that price I check that they are doing the water pump because it's a right nightmare all day job.
The petrol engines don't have rubber cam belts, they are chain driven. I've had 3 of them, 2 on gas like you!
Technically it's not a camchain, it's a timing chain as it doesn't do it in the same way as "modern" engine designs do.
Check your handbook for suggested intervals - there aren't any.
Feel slightly smug that we don't have to do that job. And feel slightly more smug that on gas ours work out less pence per mile than diesel.
Recently got the heady level of 26 mpg on a run, at 44p per litre - 101 for diesel, divide 44 for LPG, gives 2.295, multiply this by 26mpg makes an equivilent of 59.68 mpg  - fecking awesome!
Thanks for that info, I didnt realise they had a chain. Thought they were all belt driven.
Handbook what's that? thought that was for lady drivers :-)
I too have a lovely smug feeling whilst filling with gas at 41p/Ltr.
Mpg will be even better now my handbrake has been freed up so it's not rubbing anymore
hee hee hee!
But some good info in it, like how far they won't go between oil changes when used round town all the time - 3000 miles!!
Pushing it too far will damage the chain - search Vauxhall 2.2 petrol engine forums.
Bloody good price that gas!!!
Yes mpg should go up hey, and I guess that funny smell won't bother you anymore, less drag wear on the rear tyres too!!
