has anyone here attempted a clutch and rear crank seal replacement? looks like the seal has gone as seem to have oil dripping from to engine to trans plate.
manual says you need a tool (VM1050) is it really needed?
realise its half shafts out and drop the transaxle, the clutch isn't really the part that is the bother, more interested in the rear crank seal fitting.
VoyagerPig69
Seen several three seal packs on EBay e.g. (http://www.ebay.co.uk/itm/CHRYSLER-VOYAGER-2-5-CRD-REAR-CRANKSHAFT-OIL-SEAL-KIT-GASKET-CHEROKEE-/320924245926?hash=item4ab8935fa6:m:mgNeumIfoyntl2yJE7PcM4w)
Any advice?
TIA
