bri1976 Posted June 8, 2014 Report Share Posted June 8, 2014 hi my voyager has heated seats but the passenger one doesnt work any ideas :-( Quote Link to comment Share on other sites More sharing options...
0 ben Posted June 8, 2014 Report Share Posted June 8, 2014 Hi Bri - Welcome to the site I've moved your post into the Voyager section for you and I'm sure someone will be along to answer it shortly! Quote Link to comment Share on other sites More sharing options...
0 T14086 Posted June 8, 2014 Report Share Posted June 8, 2014 Welcome To start with, does the switch light up. Quote Link to comment Share on other sites More sharing options...
0 bri1976 Posted June 9, 2014 Author Report Share Posted June 9, 2014 On 6/8/2014 at 10:41 PM, T14086 said: Welcome To start with, does the switch light up.hi mate thanks for the reply the switch does light up ,i have also heard that it was a factory recall on the earlier models for the heating elements Quote Link to comment Share on other sites More sharing options...
0 bri1976 Posted June 9, 2014 Author Report Share Posted June 9, 2014 On 6/8/2014 at 9:21 PM, ben said: Hi Bri - Welcome to the site I've moved your post into the Voyager section for you and I'm sure someone will be along to answer it shortly!cheers for that mate fingers crossed i can get it fixed Quote Link to comment Share on other sites More sharing options...
0 T14086 Posted June 9, 2014 Report Share Posted June 9, 2014 There was a recall for 'possibility of fire' but I can't remember if it was for the Voyager, I seem t remember it was for one of the Jeep range however if the seat is not working then that's a different matter. Is there a black box under the drivers seat, are the connector terminals and wiring ok, lots of problems are found here. Quote Link to comment Share on other sites More sharing options...
0 bri1976 Posted June 11, 2014 Author Report Share Posted June 11, 2014 On 6/9/2014 at 11:05 PM, T14086 said: There was a recall for 'possibility of fire' but I can't remember if it was for the Voyager, I seem t remember it was for one of the Jeep range however if the seat is not working then that's a different matter. Is there a black box under the drivers seat, are the connector terminals and wiring ok, lots of problems are found here.thanks for the reply mate ill check that out when i finish work tonight Quote Link to comment Share on other sites More sharing options...
0 crispinchurch Posted May 16, 2015 Report Share Posted May 16, 2015 did you get it working got same problem Quote Link to comment Share on other sites More sharing options...
bri1976
7 answers to this question
