gumdrops Posted December 1, 2015 Report Share Posted December 1, 2015 (edited) These are 22 inch! Made by Lenso 9.5J, ET15Gunmetal grey finish. no kerb rash, some slight bubbling, otherwise the finish is very good indeed .Hub caps finished the same.Comes with very shiny wheel nuts(that you wont see once the caps are on!).Wrapped in 265 35 22 tyres with loads of tread. The wear is very even across each tyre. The tyres are all matching. Using the flash does not do the wheels justice, so I will get some decent photos of the wheels in the morning. Until then this gives you an idea of what they are like...... The Vernier is showing the tread depth of 6/7mm. The tread is the same on all the tyres As a comparison this is alondside a 16" Audi alloy £475 Edited December 1, 2015 by gumdrops Quote Link to comment Share on other sites More sharing options...
gumdrops Posted December 1, 2015 Author Report Share Posted December 1, 2015 photos have been updated Quote Link to comment Share on other sites More sharing options...
