SRW Posted November 24, 2023 Report Share Posted November 24, 2023 Electric sliding door opens if I move the handle while pushing the button, I've replaced the door actuator didn't solve the problem any ideas thanks Quote Link to comment Share on other sites More sharing options...
0 RichardM Posted November 28, 2023 Report Share Posted November 28, 2023 Trust you have a multimeter. Haven't had this problem but - A signal is sent to the sliding door lock motor P34 TN/LB to unlock - maybe if in quiet position you'll hear this actuate - there is probably a logic somewhere saying yes door lock released (as per manually pressing the latch) ??? If there is no action on the actuator check voltage & current - if voltage but no current suggest actuator buggered, if neither check wiring back to BCM. (Wiring diagram attached.) Goodluck - let us know how you get on. (I do have a spares GV if you need a replacement) Quote Link to comment Share on other sites More sharing options...
0 bignev Posted December 1, 2023 Report Share Posted December 1, 2023 Not unlocked properly via the motor? And the internal handle then moves the mechanism far enough so the motor can engage? Quote Link to comment Share on other sites More sharing options...
SRW
