Junglehead Posted November 22, 2015 Report Share Posted November 22, 2015 Hi all I'm new to the forum I've been on the look out for a grand voyager for some time and now I pleased to say I now have one !!!!!! Not had a Chrysler and I'm loving all the toys on it. How ever it does have a few niggles. It has a knock noise for the front left side maybe top mount? (any advise would be good.) Also dvd monitor don't work the player seems to work but not a flicker of the monitor. (any advise would be good.) and the rear parking sensors not working the led display seem to be missing.( were the on earth do I get one of them form??) But the car was for a good price so happy with what I have also had a great 3 hour drive home wow what a car!! 2006 XS model if that's helps Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
0 Dazandtrace Posted November 28, 2015 Report Share Posted November 28, 2015 Hi darkchild101Iv got a 2006 2.8 voyager. Mine used to do the same. But since i had the thermostat done a week ago. I dont get it anymore.also have yiu put a cleaner through it. I use bg244.(diesel cleaner) or BG44K (petrol cleaner) and it works Quote Link to comment Share on other sites More sharing options...
0 matgriff Posted November 28, 2015 Report Share Posted November 28, 2015 If the thermostat's jammed open it will over fuel, as it thinks the engine is cold. I had the same problem, thermostat fixed it :-) Quote Link to comment Share on other sites More sharing options...
0 darkchild101 Posted November 30, 2015 Report Share Posted November 30, 2015 On 11/28/2015 at 7:06 PM, Dazandtrace said: Hi darkchild101Iv got a 2006 2.8 voyager. Mine used to do the same. But since i had the thermostat done a week ago. I dont get it anymore.also have yiu put a cleaner through it. I use bg244.(diesel cleaner) or BG44K (petrol cleaner) and it works Another thing, when i start the car there is white smoke, could this be related to the thermostat issue? Quote Link to comment Share on other sites More sharing options...
0 Dazandtrace Posted November 30, 2015 Report Share Posted November 30, 2015 Dont think it related. Justvtry putting a good fuel cleaner through Quote Link to comment Share on other sites More sharing options...
0 Dazandtrace Posted November 30, 2015 Report Share Posted November 30, 2015 What you might find it could be is that the engine isnt running hot enough so over time it's going to build up alot of crap from unburnt fuel. Get your stat done whether you have an original or the cheaper option in the hose. Once its running at its temperature you will find a lot of difference. I put bg244 diesel treatment in mine and now its ace. No black smoke or anything cold. Just condensation from exhausted on cold mornings which is normal. Quote Link to comment Share on other sites More sharing options...
0 Andrips Posted December 3, 2015 Report Share Posted December 3, 2015 Junglehead, did you got the top mounts replaced? Any changes? Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 4, 2015 Author Report Share Posted December 4, 2015 I've been so busy I haven't as yet but I'm going to try to do it tomorrow. Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 8, 2015 Author Report Share Posted December 8, 2015 Hi all I've noticed that I've got a bit of a judder in reverse when going up hill slowly. Also I fill that I have to put the car in neutral when stopped as it seem to rock a bit and not very smooth. Any ideas do you think that a gearbox oil change & filter would help? Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted December 10, 2015 Report Share Posted December 10, 2015 Is it petrol or diesel? Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 10, 2015 Author Report Share Posted December 10, 2015 It's a diesel. Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted December 10, 2015 Report Share Posted December 10, 2015 Oh ok, only asking because mine was doing similar but turned out to be a misfire,but felt like the gearbox. Not much help as yours is diesel.I've have heard issues with the torque converter. Best to change oil and filter first though :-) Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 10, 2015 Author Report Share Posted December 10, 2015 Yes will do that first it's not a big thing at the moment. Quote Link to comment Share on other sites More sharing options...
0 Andrips Posted December 11, 2015 Report Share Posted December 11, 2015 I do have some vibration when I am stopped and it's in D and now even in Neutral mode. I found couple threads about that and could be the front engine mount or alternator pulley. Will change the engine mount over the weekend and if problem will stay then probably all alternator belt kit with pulleys. Junglehead 1 Quote Link to comment Share on other sites More sharing options...
0 Dazandtrace Posted December 11, 2015 Report Share Posted December 11, 2015 Mine in D at a stand still isnt to bad but what does my head in is the vibration from the exhaust iv had new rubbers fitted. And still does it. But not in neutral Quote Link to comment Share on other sites More sharing options...
0 Andrips Posted December 11, 2015 Report Share Posted December 11, 2015 I also noticed yesterday (while I was checking out the auxiliary heater) that the exhaust vibrates a lot, was thinking about rubber need change, but if you are saying that it still does it, I will not change. Then the alternator pulley to change. I can't find the threads anymore, but I think they'll where on this forum. Quote Link to comment Share on other sites More sharing options...
0 Dazandtrace Posted December 11, 2015 Report Share Posted December 11, 2015 Im wondering if i have an engine mount on the way out. Will wait for it to develop more before I worry about it Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted December 11, 2015 Report Share Posted December 11, 2015 On 12/11/2015 at 2:13 PM, Andrips said: I also noticed yesterday (while I was checking out the auxiliary heater) that the exhaust vibrates a lot, was thinking about rubber need change, but if you are saying that it still does it, I will not change.Then the alternator pulley to change. I can't find the threads anymore, but I think they'll where on this forum.What people often think as a vibrating exhaust is most times that the top thin alloy 'heat shield' has rotted out at the bolt point. The aluminium reacts with the steel bolt, the holes enlarge till they are so big the shield sits directly on top of the exhaust and vibrates like hell. Quote Link to comment Share on other sites More sharing options...
0 Andrips Posted December 12, 2015 Report Share Posted December 12, 2015 (edited) I checked the exhaust pipe under the driver seat, haven't checked at the rear, maybe vibration not so bad there. Edited December 12, 2015 by Andrips Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted December 12, 2015 Report Share Posted December 12, 2015 The Themotop C looks like this under the car, the exhaust & flexi pipe comes from item 6 on Fig. 101 in the *.pdf. best of luck. Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 14, 2015 Author Report Share Posted December 14, 2015 Hi all as this thread is going on which is good so here go's I pulled up that home opened the electric door drivers side, then I noticed some smoke coming for the under side of the car I didn't notice were it was coming form as the auxiliary heater was running at the same time. All door work as well as the heater any one heard of such a thing? Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted December 14, 2015 Report Share Posted December 14, 2015 On 12/14/2015 at 9:30 PM, Junglehead said: Hi all as this thread is going on which is good so here go's I pulled up that home opened the electric door drivers side, then I noticed some smoke coming for the under side of the car I didn't notice were it was coming form as the auxiliary heater was running at the same time. All door work as well as the heater any one heard of such a thing?- smoke coming for the under side of the car - auxiliary heater was running at the same time ! Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 15, 2015 Author Report Share Posted December 15, 2015 Yes sorry the auxiliary heater was on run over as I've just pulled up. All doors are working as well as the heater. Weird? Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 16, 2015 Author Report Share Posted December 16, 2015 It was smoking again this morning definitely coming for the under side of the car seems to be form under the driver side middle passenger seat. Any ideas? Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted December 17, 2015 Report Share Posted December 17, 2015 Are you sure it's not a leaky exhaust, that sounds about where the join is in the exhaust system Quote Link to comment Share on other sites More sharing options...
0 Junglehead Posted December 19, 2015 Author Report Share Posted December 19, 2015 Hi a bit of a update, I had a little look under the car today there is a small metal pipe just under the side door that blow out warm air which I guess is form the auxiliary heater the smoke seems to be coming there. Any ideas.... Quote Link to comment Share on other sites More sharing options...
Junglehead
Top Posters For This Question
24
9
6
6
Popular Days
Nov 25
9
Nov 28
8
Nov 27
5
Dec 11
5
Junglehead 24 posts
Semmysonic 9 posts
Andrips 6 posts
matgriff 6 posts
Popular Days
Nov 25 2015
Nov 28 2015
Nov 27 2015
Dec 11 2015
Popular Posts
matgriff
Hi I also have a GV 2007CRD, had a 2001 2.5CRD for fifteen years too :-) Front knocking is almost certainly anti roll bar bushes and or drop links... these are a very common wear out item.... if y
Semmysonic
Thanks for this info, will be very useful. It's never dull owning a voyager is it :-D
darkchild101
Great cars they are i love the toys too. Its shame the workmanship or materials used are not the best The electrics are usually a problem
61 answers to this question
