ryden
51 -
ryden last won the day on August 22 2017
ryden had the most liked content!
About ryden
- Birthday 10/21/1990
ryden's Achievements
Workshop Manual 06 2.8L Stow N Go
ryden replied to ryden's question in Voyager 4th Generation (2001-2007)
Thanks again for the info Mike, but unfortunately I'm after a Workshop Manual for my model. Many Thanks -
Hi Thanks for the links etc. Unfortunately It doesn't have the information I needed. My car is a 2006 Stow and Go 2.8L and a lot has changed due to the slightly different engine and the fact that that seats ( being stored in the floor) have moved around a lot of components. Many Thanks -
Hi All, Have the need for a GV 2006 2.8L Workshop Manual. I noticed the link to oskin.ru no longer has any documents within it - can anyone help me out or point me in the right direction? Many Thanks!
QinteQ reacted to an answer to a question: 2.8 Crd P0235 Code And Other Stuff.
Possible issues for your code below : P1651-MIL/DIAG LAMP VIA J1850 BUS IN FRAME RESPONSE ERROR P1651-MIL/DIAG LAMP VIA J1850 BUS STATUS ERROR Seems there's a few possible causes - ECM, Instrument Cluster, wiring, communication issue.
The injectors aren't bespoke/programmed to each cars ecu, if that's what you're implying?
Could you provide the Fault codes currently present on your dash? I've attached an image - On the left is the relay I assume you're referring to ( "front chassis crossbeam") - Then on the right is the location for the transmission control relays position ( which i presume you're possibly referring to as the "PCM relay" ?)
Hi Dr, I presume you've tried the common places - Chrysler ( garages) , auto factors and ebay/ amazon? Also I've inserted a table of all interior bulbs, in case it's needed.
ryden replied to frogland's question in Voyager 4th Generation (2001-2007)
All the info you'll need below: - http://www.chryslerforum.co.uk/topic/1441-how-much-antifreeze-do-i-need/ https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/hoat-coolant-22894/ -
That's correct. I managed to purchase a complete turbo and manifold for a price you wouldn't believe ( I still don't to this day!) and use the actuator off of it. I've attached the link to my post regarding the issues I had, but if you want the short story - car ran and started fine, if you tried heavy acceleration the warning light would come on until you slowed back down. After fault finding and discussing with my friend ( a mechanic) turned out to be seized waste gate and actuator starting to fail. http://www.chryslerforum.co.uk/topic/1067-hard-acceleration-causing-eml-to-come-on/ -
Nope and I managed to do all the work in place ( was an absolute bastard, wont lie) Removed the waste gate actuator, then freed off the waste gate and refitted the replacement actuator - success. -
No problem, faults like these can either be obvious or quite time consuming to identify. Possibly. I had the P2035 fault code myself. My issues turned out to be a seized waste gate and my waste gate actuator failing ( but my car ran/started fine, unless you tried to floor it) that component is the EGR solenoid. But I couldn't say if that hissing noise was okay - but I've never heard a noise like the one you have ( not saying whether that's right or wrong) -
Voyager 2004 Central Locking Problem
ryden replied to Simonmcc1972's question in Voyager 4th Generation (2001-2007)
I presume you have just the one fob simon? Also, another silly one - try the fob and if it doesn't work, give it a little tap then see if it works. ( sometimes the batteries don't sit very well in the holder) Below is an extract from Chrysler manual ( sorry for misinforming anyone) "The recommended battery is Duracell DL 2016 or equivalent, TWO cells are required. Battery life is about three years minimum." -
After reading through the post thoroughly and assuming you have no other issues with the car ( no lag, limp mode, hunting, excess smoke or rough running etc.) Plus you cant find any leaks, then its either air getting in or possible blockages ( the rubber hoses with the crimped metal ends aren't the best and injectors can get blocked easily. Also the connector you found unplugged is a bit suspicious) Here's the list Chrysler provide, for hard start checking. -
Quick quesiton frog - has your other issues gotten any better ( does it idle fine now?) -
mikebh8 reacted to an answer to a question: Voyager 2004 Central Locking Problem
Chrysler stipulate using only one battery instead of two ( ill dig it up from the manual when i get home) but I couldn't really comment on why. Not to long back I had a few issues regarding the fob locking/ unlocking and it working at different distances. Turned out to be the battery - well that's all i changed and it fixed my problems. Haha, yeah I've heard about that trick. Apparently there is method to the madness, regarding that trick.
