matgriff
21 -
matgriff last won the day on February 18 2017
matgriff had the most liked content!
About matgriff
- Birthday 10/02/1966
matgriff's Achievements
scottd2424 reacted to an answer to a question: Cambelt Replacement
After getting fed up of the constant state of near battery flatness on my 2007 Grand Voyager CRD I finally decided to get it sorted... Its not that my battery was going completely flat, but it's always just on the edge, in the mornings it just has enough to start the car, but it's never fully charged. I have no excuses as I work in R&D with power electronics :-) Step 1 - check the charging voltage... it was 13.5v both unloaded and with everything switched on, it was regulating correctly, but in my experience this is a bit low. My LR Discovery regulates at 14.4v and my neighboursMondeo at 14.5-14.6v Step 2- Unplug and measure the battery temperature sensor. It was reading about 12K ohms at 15C. Step 3- I warmed the sensor up with a hot air gun until it was pretty hot, resistance dropped to around 3K ohms. Step 4- Popped it in the freezer for half n hour, it went to 29K ohms Step 5- made up a little wiring loom with a 22K ohm 1/2 watt resistor, plugged in in instead of the temperature sensor. Step 6- checked the regulated voltage with the engine running, both unloaded and loaded, it's now 14.3v-14.4v Step 7- shut the bonnet and bask in the smugness of a simple job well done :-) To be honest I think the battery temperature sensor is an unnecessary gadget, I use a simple lead acid gel battery from Euro Car Parts, I got the biggest one that would fit, it cost £45 with a 4year guarantee, I'm happy to change it every 4 years for that price. As I've used a fixed resistor it will always charge at 14.3v regardless, which isn't a problem. I did this 4 weeks ago and it's been much better ever since, spins over great in a morning now.
if it's any help.... my 07 2.8CRD does not have wear sensors in the pads. My 2001 CRD did not either. Mat
darkchild101 reacted to an answer to a question: Getting A Spare Key
Getting A Spare Key
matgriff replied to darkchild101's question in Voyager 4th Generation (2001-2007)
Hi, no... you can get a brand new uncut/unprogrammed transponder key off ebay, I paid around £12 I think. You then need to get it cut to match your original. If you have the manufacturer code, the key supplier can cut it for you. If not just take it to a local key cutter along with your original. You then need to get the transponder programmed, in Chrysler USA cars, there's a procedure that you can follow to program it yourself, but you need at least two already programmed keys. This didn't work for me. But you can just take the newly cut one to any car locksmith and they'll program it for you as long as you have at least one original. Mat -
Getting A Spare Key
I bought a blank transponder key off ebay, there's a couple of different types but they look different so easy to get the right one. I then took it to my local cobbler who cut it to my original key for £2 It then worked mechanically in my doors & ignition. I then tried to program it using the official method (only works if you have two original keys) and then found out that UK spec chryslers don't support the key programming option, I then called my local auto lock people and they said they could program it for £25, but before I got round to getting it done I sold the car. So basically you can get the key off ebay, I even think they will cut it if you supply the original code, but then you need to get it programmed correctly. Mat -
Handbrake Cable Tensioning
matgriff replied to VoyagerPig69's question in Voyager 4th Generation (2001-2007)
I've also got a bit of an issue with my 2007 GV I had a 2001 CRD from new for 15yrs, and replaced the handbrake shoes at least twice, also freed the mechanism & adjusted loads of times, so well versed with the handbrake operation & it's common problems. In all the time I had my 2001, once I'd adjusted the shoes correctly the handbrake was tight, and came up 3-4 clicks and held. On this 2007 GV, I recently changed the shoes, and freed & lubed the mechanism as it was siezed. I set up the adjusters properly, but the lever has a long travel, seems to come up really high before the handbrake holds, almost like the cable needs adjusting ?? having never had this problem on my 2001, I'm not exactly sure where if any is the adjustment on the cable ?? I've read the earlier posts, but if it's supposed to auto adjust mine doesn't Only thing I can think of is to get back under it and double check the shoes are adjusted properly now that it's been 1000miles or so since I rebuilt it -
lovesmyvoyager reacted to an answer to a question: Wiper Size For My 2003 Grand Voyager
matgriff replied to lovesmyvoyager's question in Voyager 4th Generation (2001-2007)
Been using the exact same Michelin ones from Asda for the last three months as they were on half price then :-) I use 28" though No problems to date -
Cambelt Replacement
matgriff replied to Dazandtrace's question in Voyager 4th Generation (2001-2007)
I've done the cam belt 3 times on a voyager diesel including one time with the water pump (which was actually fine with 130K miles) it's a time consuming, but not too difficult job. You need a set of timing pins to lock the engine and cams in place, but other than that just normal tools. Took me all day to do the belt and pump, about 5-6hrs to do just the belt... -
My 2001 CRD came with 28" from new & I used that size for 15yrs. I have a 2007 GV CRD now, it also has 28" I have also seen that sites including ebay and ECP say 26" but I can only say I've use 28" now for 16yrs with no problems Mat -
VoyagerPig69 reacted to an answer to a question: Clutch And Rear Crank Seal Replacement
Hi, I had this done twice on my 2001 CRD manual voyager. Didn't do it myself as I don't have the facility to manhandle the gearbox out, but I sourced all the parts for my mate who has a garage to do. First time was at 100K miles, small drip & clutch was slipping slightly. Basically there's no need for any special tools, the flywheel bolts can be used to extract the oil seal(s) Make sure you get the 3 part seal kit, not just the outer cover one... you definitely need the O rings. Mine started to leak again at about 160K miles, worse than the original one did, replaced it again and also the clutch, the leak was fixed but the gearbox bearings failed about two months after, so I got rid of it. It's a tricky little job, but once you have the gearbox out and flywheel off it's OK Mat -
Smoke In Rear View Mirror At 3000 Revs 2.8Crd 2006
matgriff replied to Rus's question in Voyager 4th Generation (2001-2007)
2007 GV 2.8CRD auto.... In park mine will also only rev to around 2500-300rpm so I guess that's a design feature. I also notice quite a blast of smoke from mine when I give it a bit of welly, especially if it's dark, looking through the rear view mirror with car lights from behind you can notice it... however if I'm driving along at 70-90mph say on the motorway it's fine, no smoke at all. I think to some degree all turbo diesels blow a bit of black smoke when you put your foot down, it's just the way that the diesel injection system supplies the fuel in response to a WOT demand Mat -
Update : I worked out that the leak seemed to be coming from the little 3 port vacuum valve that controls the EGR. I took it off cleaned it with brake cleaner and the WD40, reconnected it and all seems well. If I disconnect the white connector at the top port, I get engine vacuum. When I reconnect it all, on starting the engine the EGR valve is at it's spring loaded rest place, then when the air con clutch engages about 20-30secs after starting, the EGR valve moves about half way. On switch off, there's no more hissing. The bottom port on the switch has a little black cap with foam in. It doesn't look airtight, but I'm not sure if it's supposed to be ??? Mat
Having a few little annoying faults with my 2007 GV at the moment....grrrrr One problem I've noticed, after switching the engine off, I can hear a hising noise for about 15-20 seconds, then it stops. I've reasoned that it's some kind of vacuum leak, because pressing on the brake pedal (ie operating the servo) when the engine's switched off causes the hissing to stop sooner. It's coming from the area to the right of the dipstick tube, there's a load of tubing/valves in that area, nothing obvious is damaged. It's definitely a vacuum leak, because I've also noticed that after the hissing has stopped, the brake pedal is solid, just like the servo is exhausted. It's probably leaking when the engine is running but I can't hear it due to the background noise. Any ideas ??? cheers After further reading on the forum, I think this could well be related to the EGR valve ???
I've noticed on my 2007 GV, that the passenger side mirror always moves past the "parking point" after it's been folded in using the switch on the steering column. It folds in fine, but when moving back to the out position, it always goes slightly too far and I have to open the window, reach across and pull it back, and it then clicks into position. Anyone else had this problem or pulled the mirror apart and looked how it works ? Thx Mat
Radio Aerial
