Carlby
9 -
About Carlby
- Birthday 04/26/1973
West Sussex
Carlby's Achievements
Hi all, Update..... I have taken my Voyager to an Auto electrician and he has given me some fault codes from the transmission. So if any one can put them in to plain English for me and can tell me how to fix them I will be truly grateful. Also can any one tell me where I can get a second hand TCM for a 2007 Diesel Grand Voyager or who may have one they can sell. The codes are : P0846 - 2-4 Pressure switch circuit ???? P0944 - Loss of Prime ???? P0706 - Check shifter signal ??? The codes have been cleared, but the issue is still the same (on the dashboard - boxes around all the gear when in "P" or "N") but the codes did not come back (yet ??) PLEASE HELP Many thanks in advance
Hi again, The only fault code I get is P0487 ??? Where can I find a TCM and PCM ?? tried ebay but only hit was an American one. Can you remember roughly how much they were (just to give me an idea) ?? and as mine is a 2007 2.8 diesel do I need to get one that matches ?? Sorry for so many questions but I am really feeling lost now
I'm getting fault code P0487 ?? What other forums are there ? My issue is getting worse When I'm driving the gears on the dash jump around from "D" to "3" and "L" and then the actual gears jump between "D" and "L" (when the revs suddenly pick up and then it changes back again...)
What is TCM and PCM ? Where are they and how can I check them ??
The fail code P0487 ????
Hi, It's not "stuck" in a gear, I can select Drive (but when in drive it sometimes jump down to "L") and Reverse , just cant select Neutral or Park (according to the dashboard, but it is Park when "P" is selected as in the car wont move ???) Its very confusing:( I will look around more but not very good at looking around forums etc (not very good on internet) Cheers
Carlby started following Auto Gear Box Issue
HELP..... I am not very mechanical, so if you can help please keep it simple for me. The issue has gradually got worse, it start about a month ago. I notice that when I started my Voyager up, on the dash all the gears had boxes around. This happened every now and again and I thought may be I had not fully engaged the column shift in to the correct gear. Shortly after as I was driving in "D" it suddenly changed itself to "L" (the column shift was not moved) and then jumped back to "D" this has happened a number of times now . I had the gear box oil & filter changed as I did not know when it was last done and thought it may help. But gradually it has got worse to the extent that every time I start the Voyager all the Gears are always got boxes around when the car is in "P". I move through all the gears and when it is in "P", "N" (some time this clears it, but less so lately ) all the gears show boxes also sometimes "3" & "L" do as well. As I have electric doors and boot, it means I can not open them while the ignition is on as it does not appear to know it is in park. Can anyone help ?? or know what I can look at/ check before taking it to a garage ?? Looking forward to any assistance you can offer Carlby
Carlby reacted to an answer to a question: Hello From Not So Sunny Bognor :)
Hello All, What lovely weather we are currently having...... I am a proud owner of a 57 plate Grand Voyager. This is our 3rd Voyager/ Grand Voyager we have had them for the last 6 years with very few problems. My current Voyager is the 2.8 Stow & Go model with Electric doors and boot etc. I have only just discovered this forum and I am hoping there will be members on here that will be full of help and knowledge. I am looking at getting a tow bar fitted to my car, is there any advise about whether it is possible to have a fixed tow bar that does not set of the reversing sensors ?? or setting the sensors to "ignore" the tow bar ?? while I am here, when I brought the car the previous owner's dog has chewed the arm on one of the middle (single) stow & go seat. Is there anyone selling the arms (or seat) or can anyone recommend a breaker that may have an arm in ?? Cheers all, looking forward to hearing from you Carlby
Hi All, What lovely weather we are currently having I am a proud owner of a 57 plate Grand Voyager. This is our 3rd Voyager/ Grand Voyager we have had them for the last 6 years with very few problems. My current GV is the 2.8 Stow & Go model with Electric doors and boot etc. I have only just discovered this forum and I am hoping there will be members on here that will be full of help and knowledge. I am looking at getting a tow bar fitted to my car, is there any advise about whether it is possible to have a fixed tow bar that does not set of the reversing sensors ?? or setting the sensors to "ignore" the tow bar ?? while I am here, when I brought the car the previous owner's dog has chewed the arm on one of the middle (single) stow & go seat. Is there anyone selling the arms (or seat) or can anyone recommend a breaker that may have an arm in ?? Cheers all, looking forward to hearing from you Carlby
