imac2626
    8
About imac2626
  • Birthday 07/29/1975
    Lancashire
imac2626's Achievements
  1. Exactly the same thing has just happened to me, 2008 6 speed auto grand voyager V (RT). All forward gears are fine but very little or no reverse gear. Dropped the transmission oil and filter to replace them both (cheapest option to try), but alas, still the same. Found some lovely little teeth in the transmission sump as well. Good job I work in a garage, looks like it's gonna be a gearbox out job ha ha
  2. Hi all, I've got a 58 reg Grand Voyager, suddenly lost reverse gear but still have all forward gears. I've done 98k miles and am gonna change my transmission oil and filter as all the diagnostic codes point to that. Just wondering what other oil is used as an alternative to ATF+4 as it's very expensive. I've heard Dexron 3 is a good alternative. Any help or advice would be brilliant. Cheers.
  3. I noticed on my mk v that both of the pipes had come off the actual washer units. I was going through 5 litres of screen wash really quickly ? anyhow, I simply jacked up the front of the car slightly and reached up inside the bumper and re attached them. Other than that you could check the fuse.
  4. It is yes, I just can't understand why or how this fault is occurring. The bulb is obviously ok as it lights up when I remote unlock the car
  5. Hi everyone, I've got a 58 registered grand voyager. When I remote unlock my car both headlights come on, yet, when I start the car and turn the headlights on only the offside headlight works ? it can't be a fault bulb as they both work on remote unlock. I can't work it out nor understand it, any help please?
  6. I've got a mark 5 Grand Voyager 2.8 CRD Limited and mine usually hovers around about the same place, the heaters blow nice and hot as well.
