steviec2000
26 -
About steviec2000
- Birthday 04/21/1978
Sheffield
steviec2000's Achievements
Rear Air Con Block Off
steviec2000 replied to steviec2000's question in Voyager 4th Generation (2001-2007)
Thanks bignev, sounds like the job is beyond my level of ability to fix! Has anyone had a leak from the aircon pipe and managed to fix it so that either just the front air conditioning works or front and rear? -
Correction: the fluid leak is dripping off a pipe near the rear tyre well, drivers side . -
steviec2000 started following Warning Chime Has Stopped Working , Rear Air Con Block Off , Rear Air Con Block Off and 2 others
Hi, I've a leaking air con system which discharges about a day after being re gassed. Is dripping fluid from near the rear tyre passenger side. Looking on Google it seems a common and expensive problem. However I've seen there are rear air con block off kits which allow the front air con to be recharged and work. Has anyone any experience of obtaining the kits and having them fitted here in the UK?
Hi, over the past couple of weeks out of the blue my 2005 3.3l petrol Grand Voyager is having difficulty starting when left stood for a while (e.g first thing in the morning and say after 5 or so hours later if left). The engine turns over but doesn't fire, after 4 or 5 attempts it will fire and does not have a problem starting again until it is left to stand again for several hours. I'm also having a problem in that once the engine is warm (only when warm never when cold), the car will intermittently stalls when at low speed, e.g. at traffic lights or slowing down for a roundabout). When it happens, the engine just dies without warning. When I check the fault code I get a P0171, which I see is the system is lean. I'm unsure if the two issues are related or separate? I've checked the battery and it is fine, I wasn't sure if the issue was the fuel filter, O2 sensor or something else. Any ideas Thanks
Accelerator Pedal Not Working
Thanks. I've just to come to look at it now and the throttle is back.?! Could it be the cold weather this morning? -
Hi, have come to my 2005 Grand Voyager 3.3l this morning and I have no acceleration?? The accelerator pedal feels very spongy and the pedal feels higher than normal, if I press it there is no throttle response. The car creeps forward or back or if I put in gear, but without throttle I'll not get far. Does anyone have any ideas? Sorry no error codes?
steviec2000 posted a question in Voyager 4th Generation (2001-2007)
Hi, I've had some recent work (routine service) and now the warning chime that used to sound if I had left the headlights on or forgotten my seatbelt now doesn't chime. It now doesn't chime for anything at all. The garage that did the service are telling me they haven't done anything to cause this and are refusing to help. I've tried disconnecting the battery and leaving for a while with no joy. What makes me think the garage have done something is that I telephoned them during the service to check when it would be completed, I could hear the chimes going continuously in the background now I think back to that call, but never thought anything at the time. Does anyone have any ideas how this could have been disabled and how I can turn back on? Thanks. -
steviec2000 reacted to an answer to a question: Grand Voyager Stalls At Low Speed In Drive Intermittently
