macuniyanukukuk
68 -
macuniyanukukuk last won the day on January 8 2018
macuniyanukukuk had the most liked content!
About macuniyanukukuk
- Birthday 05/30/1972
leicestershire
macuniyanukukuk's Achievements
Plastic Rocker Box Covers
macuniyanukukuk replied to AustinM64's question in Voyager 4th Generation (2001-2007)
Hi I have the same engine. Mine doesn't Have a plastic cover. You mean like a sound insulation cover? Thanks -
Is it the same fitting as stow 'n' go. Or so if someone Can provide a link would be interested. Thanks
macuniyanukukuk reacted to an answer to a question: Parking Sensor Fault (Red Lights) - No Ticking Sound
Rough Idle On 3.3 Petrol Auto
macuniyanukukuk replied to TinTent's question in Voyager 4th Generation (2001-2007)
Hi Wow there you certainly have done a lot of work on your GV. I have a 2007 3.3 petrol, I have a very similar problem to yours. I don't have rough idle but do have body shake when in drive. I seem to think mine may be related to the engine mounts. I think maybe you should be looking at the same because rubber tends to be more softer when hot. Maybe something to try. Let us know how you get on. -
Hiss/high Continual Ssssss Noise From Acc Belt
macuniyanukukuk replied to andyb2000's question in Voyager 4th Generation (2001-2007)
That's parts and labour andyb2000. From what I remember just the new belt was about £24 from chrysler -
Forgot to mention 3.3 petrol 2006 -
Hi I have just done mine sounds like a completely different engine. I changed the idler, clutch on the alternator and the belt. Idler and belt from chrysler. Clutch from alternator/starter motor specialist here in Leicester. About £120 all in for my trouble. Well worth doing. Mac -
Where Can I Go For Parts.
macuniyanukukuk replied to Hedge's question in Voyager 4th Generation (2001-2007)
Try ebay and main deeler- 2 replies
- spares
- scrap yards
- (and 4 more)
Drivers Electric Window Not Working
macuniyanukukuk replied to phildsharp's question in Voyager 4th Generation (2001-2007)
Does sound like the regulator. It's an easy fix. On mine took the motor apart wd40 and it started to work again. That was 2 years ago. If you look on YouTube plenty of video's. Hope that helps. -
QinteQ reacted to an answer to a question: 3.3 Petrol Won't Crank
macuniyanukukuk replied to Andrips's question in Voyager 4th Generation (2001-2007)
I had exactly the same problem on my 2006 3.3 it turned out to be a wire loose on the starter motor itself. -
Leaking Intake Elbow
macuniyanukukuk replied to peterdemski's question in Voyager 4th Generation (2001-2007)
Have you tried the main dealer? -
Insurance
macuniyanukukuk replied to roberttherebel57's question in Voyager 4th Generation (2001-2007)
What model do you have? I have a 3.3 petrol with Aviva paying about the same. But then again the premium is dependent on your age and postcode -
18" Alloy Wheels For Sale, Brand New Tyres
macuniyanukukuk replied to robbie2red's question in Voyager 4th Generation (2001-2007)
How much -
Hi All I wonder if anyone can shed any light on my 2006 3.3L Voyager stow&go. The a/c works fine on the front blowers but as mine is dual both front and rear, when the a/c is switched on it only blows cold air from the bottom air vents near the feet in the rear. There used to be cold air coming from the top air vents before. I have tried all the usual settings auto/manual etc. Any help much appreciated. Thanks guys.
macuniyanukukuk started following A/c In Rear Not Working
Thermostat On V6
macuniyanukukuk replied to tomada3's question in Voyager 4th Generation (2001-2007)
Hi I did mine a while. It's a very easy job. No need to drain the radiator. No need for gaskey sealer. Let me know how you get on. -
No Rear Brake Lights
macuniyanukukuk replied to MartyMcFly's question in Voyager 4th Generation (2001-2007)
What was the fault?
