Wayne300c
13 -
Wayne300c last won the day on September 18 2015
Wayne300c had the most liked content!
About Wayne300c
- Birthday 05/20/1971
Northumberland
Wayne300c's Achievements
There's a few on eBay , mostly seem to be from sellers in the USA
There's a few of us have had problems getting into gallery , but our queries as to why have so far not been answered
Switch ignition on , then press the buttons on the steering wheel with the music note on & the compass one at the same time and hold down for a few seconds , then menu should pop up on the display . Use up & down buttons to scroll through menu , it gives a lot more info , ie oil pressure, charging volts , engine running temp & the all important 0-60 timer . I will be using the timer now I know it's there !!!
I've just found a hidden menu on my 300c info centre , it includes a 0-60 timer among other things , has anyone else come across this ?
Wayne300c started following 300C Front End Rattle. and Secret Hidden Menu
Is there any way or any device available to enable me to play an iPod or mp3 through the car stereo . My car is a 2007 model with the 6 cd / sat nav combination fitted & on the front of the unit it actually says "mp3" but cannot find any connection . Any ideas ?
I've been on here for a couple of months now and would like some help . I've tried to put some photos In the gallery but when I go to the gallery it just keeps telling me that I don't have permission to do this , so I tried to send an email to the administrator for advice , but it comes back saying message failure . Has anyone else had problems & if so did you get lt sorted . Any help would be appreciated , cheers
Cheers , ianbunnybell , will try and get a look at it this week , I think it might be a a ball joint as I noticed today that it also creaks at low speed when going over bumps & as the ball joint moves in all directions I will be squirting the wd 40 into them first . I'll report back with the outcome . Thanks again
Pleased to hear you got your rattle sorted , I fitted the new drop links to mine and the rattle stopped , but annoyingly it has now developed a creaking / squeaking sound on the n/s which gets worse on left hand lock . Any suggestions before I start investigating ?
Here's the linkhttp://pages.ebay.com/link/?nav=item.view&alt=web&id=281738982965&globalID=EBAY-GB
Think I spotted one on eBay if that's any help
Cheers for the feed back@@Ianbunnybell , I've got 2 new drop links coming from the 300c shop for fitting at the weekend & while I've got the wheel off I'll check the calliper aswell & let you know if I find anything ,thanks
I've just joined the forum & have just posted in "bumping noise " topic on the same subject . I had this problem on mine & first thing I tried was to disconnect the antiroll bar drop link on the side that was knocking then went for a drive . Rattling stopped , but the drop link didn't show any signs of wear when connected but when disconnected the bottom ball joint was fairly easy to move which indicated that there was wear . It's the cheapest part to replace so try that first . Hope this helps
Hi I've just joined the forum & have owned my 300c since December and mine also has this issue . The knocking on mine is due to the drop links on the front anti roll bar . I used a process of elimination to find the problem ie disconnected one side drop link the went for a drive , if knocking stops you've found the problem . Having read about these cars I believe that they are prone to suspension wear due to our wonderful potholed roads , but replacement parts are plentiful on eBay . Hope this helps .
