djjas
djjas last won the day on November 6 2016
djjas had the most liked content!
About djjas
  • Birthday 06/29/1971
    Portsmouth UK
Contact Methods
djjas's Achievements
  1. djjas
    Mpg
    I asked my local Chrysler specialist this question and he said that the fuel computer is calibrated for UK use. So your actual reading is the correct one. Even so for a car that weighs over 2 tonnes and had a 3ltr 24v turbo diesel engine that's still a very respectable MPG figure. I managed to achieve 56mpg on a flat road at 65mph with the cruise control on. Let's see the hemi's compete with that lol
  2. Service schedules are normally accessed via the sat nav screen (of you have it). If not then I'm not sure. Also I can't help with the bulb issue as I've never had one blow.
  3. As far as I'm aware if you have the knob in the auto position the climate control automatically adjusts the air temperature in accordance with the temp dials. The aircon switch flashes when pressed to indicate that it isn't necessary to select the aircon as the system does it automatically. You do have to manually select air recirculation to "on" though if you want to fully benefit from the aircon.
  4. Hi. I need some advice please. I have a 2008 300c and have an issue with the passenger side mirror. It dips down ok when selecting reverse but won't return to the original position when taken out of reverse. Also when unlocking the car sometimes the mirror glass moves on its own! I have twice replaced the mirror unit but the fault remains so what should I look at to try and sort this annoying problem? Any help much appreciated.
