almaff
13 -
almaff last won the day on November 20 2016
almaff had the most liked content!
About almaff
- Birthday 02/03/1960
almaff's Achievements
robbie2red reacted to an answer to a question: Parrott Hands Free
Hi Andy,thanks for your reply. I've been in touch with a local audio specialist and they say that they can fit the system in,I shall book mine in and let you know what happens.
Does anyone know what ISO lead I need to fit a Parrott Bluetooth into a 57 plate grand voyager? Apparently there are three different types of leads. I have the rb3 system with the sat nav and DVD. Many thanks
My 57 plate grand voyager's engine management light has come on and the automatic gearbox won't change gears. Does anyone know what has to be done? The error code reads P0891. Would appreciate a reply as Chrysler servicing can't book car in till December 3rd. Many thanks
My 57 plate grand voyager's engine management light has come on and the automatic gearbox won't change gears. Does anyone know what has to be done? The error code reads Po891. Would appreciate a reply as Chrysler servicing can't book car in till December 3rd. Many thanks
Does anyone know the reason for no sound coming through the speakers, and yet the system is turned on? I have a 57 plate GV with the factory fitted dvd and sat nav installed. Could it be the amp? Would appreciate some thoughts, many thanks.
Hi all. Does anyone know about the above? My Grand Voyager is losing water,i can't find out where it is going,no leak and no water under the car. Can anyone help? Many thanks.
Hi everyone, I replaced my DVD monitor on my Grand Voyager as the catch was broken and the casing was cracked. I could only find a replacement from the USA, after studying the picture of the unit on ebay, it looked exactly the same as mine, so I ordered it. When it arrived I plugged it in and fitted it in place. I put a DVD in and the picture comes up (With sound) but, the screen keeps flickering. I noticed that the circuit board is slightly different from the original and the lugs which attach to the circuit board are a different size. Could it be that the screen is not compatible with mine?
Hi everyone, got a 57 plate executive xs. I put a dvd in the player and I only get sound with no picture, the picture came on at one time, but that was by playing around with a couple of the buttons. Any idea if i'm doing something wrong? Many thanks
Thanks for reply, I think I'll give them a miss.
Hi everyone, does anybody know if running boards from a 2003 Chrysler grand voyager, fit a 2006 stow n' go model? Many thanks.
Hi, my Grand Voyager (56 Plate) started knocking after I went over one of those nasty speed humps, it seemed to get worse and worse and sounded as if it was coming from the passenger side, It sounded as if it was coming from inside the dash board, when I got out to have a look under the passenger side wheel arch, I noticed fluid dripping on to ball joint. Does anyone have an idea what it could be? Being bank holiday, I won't be able to get it to a garage until Tuesday. Many thanks
Hi, thanks for your reply. I put a new battery on and after approx. 3 hours, exactly the same happened. I'm now expecting it to be the alternator as it's obviously not charging. Shall get alternator tested first thing on Monday morning. Again, thanks for your swift reply.
Hi, my 2006 ''56'' plate GRAND VOYAGER has been playing up a little bit lately. Sometimes, it's sluggish when I start (Just about starts), other times, it just starts straight away. (Plenty of power) This afternoon it just died on me,I tried starting it and all it did was click, click, click. A friend of mine gave me a jump start and it started, got about 50 yards up the road and it died again. He put the jump leads on again, but this time we gave it about 10 minutes to let the battery charged up a bit. Anyway, started it again no problem. As I was driving it home,all the dash lights came on (Airbag,ABS,Seatbelt,Management etc etc) and the speedometer and rev counter was doing a full turn. Eventually the gearshift markings (PRDN3L) started flashing and eventually faded out,the car shuddered and finally cut out again. Does anyone know if it's the battery or the alternator? If it's them at all.
