marc1984
14 -
marc1984 last won the day on June 7 2015
marc1984 had the most liked content!
About marc1984
- Birthday 10/22/1984
Great Yarmouth
marc1984's Achievements
Limo19 reacted to an answer to a question: Water In Fuel
jayzee69er reacted to an answer to a question: Alloys
Looking For Limited Crd Sticker For Gv
marc1984 replied to darkchild101's question in Voyager 4th Generation (2001-2007)
Sorry had a quick look only other thing to do Is look at dismantling ones there's a few and ask for the badge -
Replacing The Pcm On A Voyager
marc1984 replied to seezed's question in Voyager 4th Generation (2001-2007)
Looking through Google and my autodata disc the immobilisers are linked to their own ecu (pcm) -
marc1984 started following Few Problems and Headlight Washers
I've had my grand voyager v6 limited for almost 3 years and never realised till now it has headlight washers checked handbook and says with lights on use washes as normal,but nothing I've swapped relay with the horn one and horn works fine there's no noises or anything
06 3.3 Revving Issue
marc1984 replied to Semmysonic's question in Voyager 4th Generation (2001-2007)
Yeah mine goes to about 2500 3000 seems like a low rev limiter -
You can buy them off eBay -
The only way is to check all connectors. and play hit or miss
Front Discs And Pads On Grand Voyager
marc1984 replied to leeoliver2010's question in Voyager 4th Generation (2001-2007)
I won ebay auction for green stuff pads and drilled and grooved disc's all together 76.80 -
New Owner But Some Problems
marc1984 replied to cappsie's question in Voyager 4th Generation (2001-2007)
Yeah it did sort problem and are easy to replace as I've done all body and engine wwork myself -
The fitment you are looking for is 5x114 I've got a set of rx8 18s on mine
When I replaced my rear bumper due to owner before driving by touch. when the bumper goes onto the car the corner bits under lights should slide on top oof a black plastic trim
I had that I replaced the anti roll bar/sway barbushes with blue poly bushes after test drive on uneven ground was still clunking after having a mate rock it while on ramps the drop link on drivers side had given up apparently common if anti roll bar bushes aren't done quick enough
I have spare wing mirrors I took off a cheap one I brought. -
got a 2002 grand voyager v6 and got a few niggles some mornings it starts fine but the battery light comes on lose all power steering for maximum of a minute. headlights are shocking brought a set of 8500k bulbs and not helped at all.
under either the filter or pump will be a release screw as diesel sits on top of water drainage it till its just diesel
