alunjones999
alunjones999 last won the day on June 7 2014
alunjones999 had the most liked content!
About alunjones999
  • Birthday 01/02/1955
    Norfolk, UK
alunjones999's Achievements
  1. Useful link to get error codes manually. http://www.allpar.com/fix/codes.html
  2. Not sure about the starter motor, but it did seem that a low battery voltage was the problem. Found the problem or problems I think, think original battery was on way out, but I also found a faulty door catch on the rear door, which was causing the interior lights to come on overnight and drain the battery. Door catch snapped yesterday so got it welded and today its starts fine. Well so far so good anyway. Cheers for the advice guys much appreciated. Also found a good link for error codes without a diagnostic kit http://www.allpar.com/fix/codes.html
  3. Update, new battery didn't work still same problem!!!
  4. Cheers for that 7up, found that out early on, easy to nudge it sometimes by accident too. Yesterday it just wouldn't start at all, tried boosting the battery but nothing, still clicking. Eventually though the battery did give up the ghost wouldnt even take a charge at all so presume it was thats it. Bought new one today(that was an effort, ringing round to find the one with the posts the correct way round!!!) it works now we'll see if that is the problem over the next few days.
  5. Grand Voyager 3.3 V6, just recently had problems starting, turn key and all you can hear is clicking, thought it might be starter motor not engaging but after a few attempts electrics died, battery looked in a good state so called greenflag, he thought it was battery and put a booster on it, few attempts and it started ok. Was fine for a few weeks then happened again couple of days ago, same thing ( did notice the dials go funny on turning key) disconected battery put a charger on for 10 minutes looked at right voltage so tried again, still clicking, but 2 more attempts it fired up and been fine since. It needs a service so will get it hooked up to check for faults, but anyone had this before? I don't think its the battery, as i say there is a condition light on it which is green, and when I hook up the charger it registers 13.8volts, but lights and dials do a dance when the fault is there???? cheers Alun
  6. Hi, Found you through Google, have a 2003 Voyager 3.3 V6 adapted for wheelchair. Had it for a year now, few things going wrong so thought I'd look for advice.
