seagoon
    26
seagoon last won the day on January 21 2024
seagoon had the most liked content!
About seagoon
  • Birthday 12/12/1947
    scawby lincolnshire
The recent visitors block is disabled and is not being shown to other users.
seagoon's Achievements
  1. 2013 chrysler delta rear crash bumper, removed from my car to fit the tow bar Pick up only from DN20 £50.00
  2. seagoon
    turbo clamp
    Hi everyone this is just to let everyone know that the part number for the Delta turbo clamp is from Elring and the number is 939.460 its 73mm took me ages to find the right size Regards Dave
  3. Hi I did find it and what a mission to reach it I changed the pressure sender and its all OK now thanks to all for your input Regards Dave
  4. Hi Big Nev, after finding out its the oil pressure sensor, I was led to believe that its near the oil filter, well after just about dismantling the car I find its not there !! so can you point me in the right direction ??, having got round to fitting the oil pressure sensor, I cant find it can you help me out ? Regards Dave
  5. Hi Big Nev my oil pressure sensor was also the fault thanks for your input Regards Dave
  6. Hi Deltamike, I connected the Multiecuscan found the cruise control module I turned the dashboard light to on, and thats it took it for a drive and it works perfectly I tried at different speeds and no problem, the clutch and brake controls to switch off the CC ALL WORK WITHOUT ANY INPUT TO THE ECU I am very pleased with it Regards Dave PS I have to now find the bottom plastic cover for the steering column
  7. Hi, thanks for your reply, yes I fitted the cc with the 3rd stalk on the steering column, it does not have start/stop. What I wanted to know basically does the Multiecuscan have the ability to program in the CC, has of now I have not tried it but Im going to have a go right now and I will let you know and anyone else who may be interested in changing the steering column controls, Im now 76 and a long drive like going to my daughters in Scotland, does not do me any favours the right foot tends to go into limp mode I will be in touch Regards Dave
  8. Hi everyone a HAPPY NEW YEAR TO ALL I have just fitted the steering wheel controls that includes the cruise control can anyone advise me on connecting to the ECU using Multiecuscan ? the wiring was there and I connected all the wiring back in its proper place, I would like to know is there a specific way to get the cruise control to work ? I have not tried has yet and I thought it better to ask rather than take a chance with the ECU Any help would be appreciated Regards Dave
  9. you can turn off the cornering lights on the dash menu, also the "light out" check your number plate lights Regards Dave
  10. Hi ,recently when i start first thing in the morning I get a warning of "low oil pressure switch off" I dint know if its the oil pressure sender or could it be a failing oil pump? when I start it the second time theres no warning ? it only does this at first start up, oil is full and new with a new filter also, has anyone got an ides as to what it could be? Please let me know Regards Dave
  11. seagoon
    2013 Delta
    Hi everyone I was right with the thermostat it had gone bad fitted a new one + new antifreeze and its all good now.
  12. seagoon
    2013 Delta
    I recently had a water leak coming from the EGR cooler case there was a small crack in it, I purchased a 2nd hand one and fitted it now after 2 months it has failed again in the same place as before the EGR casing the crack is in the same place has the old one,!! could this be a faulty thermostat ?? my thinking is if the thermostat is stuck then the water cannot flow and the pressure build up would possibly crack the plastic EGR cover. Has anyone got ant ideas or had the same problem ?? Regards Dave
  13. Hi everyone, I had to leave my Delta for a while has I had an operation, and not allowed to do anything for a while. Now that IM RELATIVELY FIT I came to refit the vacuum system and Ive forgotten where the pipes go, does anyone have a photo or any info has to where these pipes go, I thought I had it, but upon staring the car I get a P2563 on the dash "variable geometry turbo position" which I think is caused by the mix up of the vacuum pipes. Can anyone point me in the right direction?? Regards Dave
