cjtec
About cjtec
- Birthday 10/04/1963
cjtec's Achievements
Beeping Noise/battery Draining
cjtec replied to Neipas2015's question in Voyager 4th Generation (2001-2007)
As above, ensure key is taken out in the off position. If the barrel is worn the key can just be removed any position keeping ign or aux on. -
Oil Level/dipstick Problem On 2008 Grand Voyager Touring
cjtec replied to terrymic's question in Voyager 5th Generation (2008-2016)
The cap unscrews, dealer only dipstick for level check -
Its just the light to tell you the cabin heater is on. Nothing to worry about.
Front Discs And Pads On Grand Voyager
cjtec replied to leeoliver2010's question in Voyager 4th Generation (2001-2007)
If memory serves its 5mm allen key socket for caliper and 21mm socket for carrier -
Cabin heater, normal. Did you have 3 wavy lines on the panel above the cluster?
Passenger Side Water Drips But Doesn't Seem To Be Coolent
A/c draining, you must have had the a/c on or set to screen -
Problems Finding A Clutch Slave Cylinder
cjtec replied to Bazzerio's question in Voyager 3rd Generation (1996-2000)
How much is a dealer asking and if the pedal is fully depressed it should crank/start -
Looking For Grand Voyager Mechanic Asap
cjtec replied to immy000's question in Voyager 4th Generation (2001-2007)
Priority would be rear main oil leak and check the breather is not blocked, the other stuff is normally something to just keep an eye on. -
Test drive the twin air, fab engine you will be surprised
Headlamp issue was switches
There is a rubber bung in the backplate, remove and turn the shoe adjuster with a screwdriver until the wheels lock, then back off a few clicks until free to rotate.
Power Sliding Door Problem
cjtec replied to speedy7485's question in Voyager 5th Generation (2008-2016)
The doors will only start to move with the electrics once they are part way open. Its a little confusing how you have written the complaint. Do the inner and outer handles open the doors? -
2.5Crd 2001 Lights Flickering
cjtec replied to petecee's question in Voyager 4th Generation (2001-2007)
You say dials, illumination or gauges stopped working? Light switches have an occational issue. -
Hi Fellow Members 'need Assistance'
cjtec replied to Jayman2015's question in Voyager 4th Generation (2001-2007)
Nope
