moggies
moggies last won the day on February 10 2015
moggies had the most liked content!
About moggies
- Birthday 10/04/1963
moggies's Achievements
moggies started following Chrysler Software Update , Mygig Update Help For A Complete Newbie , Power Sliding Door Problem and 1 other
What 3 letter code is on the bottom right?
I think there are 3 pressure switches, so if they did two, its probably the other. Its the 2/4 pressure switch code. Any other codes as it maybe something else causing this?
Getting Music Off Hard Drive
moggies replied to joonsey's question in Voyager 5th Generation (2008-2016)
To take the files off hdd it needs to be placed into dealership /service mode and an external hdd connected. -
moggies replied to speedy7485's question in Voyager 5th Generation (2008-2016)
Just a few screws and stubbon pull clips and you need to have the door nearly shut. -
When does it stall, mainly from cold while manouvering?
This is RT model, yes? Thrre are cables for inner and outer handles. I would suggest a peek inside to check they are connected. -
Driver Side (Lh Steering) Won't Heat Sometimes
moggies replied to VOYAGER1's question in Voyager 4th Generation (2001-2007)
What year build is the car? -
Ive just joined and have had some CJ experience, what were the questions you asked
No need, extensions and magnet
Does the inside handle work? Maybe worth pulling the door panel off and checking things are connected. -
Eyore28 reacted to an answer to a question: Air Con Compressor.
2.8 i presume? Resonably easy, but you obviously need to recover the gas 1st. Illegal to vent to atmosphere! 13mm sockets, extentions etc. Wind the pas drive belt on/off, no tensioner. Forgot to mention to make sure the new compressor has oil in it. Turn upsidedown and drain into a container the old pump, do the same with the new and compare the amount of oil, then refill.
moggies replied to Msd26129's question in Voyager 5th Generation (2008-2016)
Your dealer cannot say that! They may charge a bit of time for investigation to see if its relivant, but the time for the bcm flash is 0.5. -
Hi Fellow Members 'need Assistance'
moggies replied to Jayman2015's question in Voyager 4th Generation (2001-2007)
What oil is it? It should be atf 4. Anything else will give you difficult gear selection -
Hello - New Gv Owner With Queries
moggies replied to Jaz's question in Voyager 4th Generation (2001-2007)
If your unsure of the service history, i would be inclined to just get on and do the timing belt kit. Major service would be all the filters, brake fluid and antifreeze. Tha sliding door may have a broken wire in the ladder track, most common.
