Hello! The car is from 2003 and has the 2.5crdi engine. Ran fine and the other morning did not start, it will sort of run on easy start. So far i have changed the lift pump,high pressure pump and tried 3 different fuel pressure regulators on the pump, but no luck. No fuel pressure at rail, when cranking the fuel pressure sensor shows 0.6v it should be higher when it sees fuel pressure. I have checked the wiring from the fuel pressure regulator to ecm and also the fuel pressure regulator wiring to ecm, all is fine. And also when i loosen the fuel pipe on the high pressure pump and crank it there is almost no fuel coming out. What will cause the fuel pressure regulator to not let fuel out of pump? On the scan tool i have no fault codes and i can see the engine rpm when cranking. Any ideas? Really stumped here.
