jakedamuss
16 -
About jakedamuss
- Birthday 01/14/1976
Cambridgeshire
jakedamuss's Achievements
Hi all newbie again. Here's my second issue. Pressing keyfob: Pess once it only opens drivers and passenger side. Have to press twice to open passenger front and rear. Same fir locking press once and it locks only front driver and rear driver's side. Have to press twice to lock the passeenger front and rear side ? And the boot only opens with key. It does have a tow bar fitted so may be it's the electrics been bypassed. The boot opening with a key is a ? any ideas for a simple fix. Sorry for long winded thread. I await your replies.
Hi all thankx for the replies checked in the owners manual, not written anywhere. So it's going to have to come out. Shall be tackling over weekend. Few more issues but I post another thread.?
Hi do I use radio release pins to get to it or is it take parts off front s fascia trims off.
jakedamuss reacted to a post in a topic: Roof Cross Bars For A 2006 Stow And Go Grand Voyager
Hi all recently bought 2.8 CRD LX. Unfortunately i do not have the radio code. This is in case the battery has to be disconnected in the bear future. What's easiest way of achieving this rather than going to main dealer.?
Hi all my manual gearbox changes are very tuff in 1,2 and the clutch pedal is going further to the floor when pressed gradually got worse over time. I like the car but ever since I've owned the car the gear changes have always been problematic. Any advice..
Abs Light 2003 Crd Voyager!
jakedamuss replied to jakedamuss's question in Voyager 4th Generation (2001-2007)
Thanks for the response, i ordered one of ebay which is much cheaper than main dealer price so fingers crossed it works o.k. does the abs light reset itself once the sensor is replaced or does it have to be cleared via diagnostic tool. The bolt holding the abs sensor snapped so thats going to be a nightmare getting that bugger out any suggestions?? -
Hopefully its just the sensor then. -
hi gu ys still no response from any members its due for mot very soon is there anyway i can make code dissapear and get abs sorted afterwards i tried negative batter terminal thing but that didnt work i really need some help -
Hi all my ABS light stays on all the time whilst driving, so i got it checked out and the garage said it was fault code 11 and carb 22? he said code 11 is left front wheel speed sensor and carb 22 he wasnt sure but could be some internal failure with the ABS system. Any ideas or help would be use full in what i should do next, or may be a cheap FIX.http://forum.chryslerminivan.org/images/smilies/confused.png
Cheers. Any other members done there fuel filter? I went to my local car centre they said there are two filters for fuel is that correct? Also will I have to empty the fuel tank to tackle this. Also thinking of using a complete oil flush 5ltr to completely get all the crap out and put new oil in afterwards any advice?
Hi so ive been reading that alot of people using 5w-30 so i need to decide on that. The gear box and power steering use the same ATF4?. HOW ABOUT FUEL FILTER? Are these jobs easy for a d.i.y or best going to garage?
Thanx. Look forward to using the forum
Hi all just joined the forum. I needed some advice please my car (58,000mls) needs a service, oil and filter change what oil grade is best (53-30 or 5w-20?) and how much quantity shall i need, also fuel filter, and gear box oil change is it ATF 4 that i would need and how much quantity. I am thinking of doing the service myself just wondering any problem areas that i might stumble across. If i decided to go to a garage how long you think it will take them. Any tips be helpfull.
Hi there can u send some pics to [email protected] if its still available.
