Foggy
    24
Foggy last won the day on April 17 2023
Foggy had the most liked content!
About Foggy
  • Birthday 07/08/1962
    Edinburgh
Foggy's Achievements
  1. I've replaced the brakes on mine ,and my last one quite easy once you free all the parts off ,which were both seized solid
  2. Starts fine . Also noticed the red light on the steering column not flashing . Changed battery on fob . Took out iod fuse . I'll live with just using the keys to open it .
  3. Does anyone know what the 5 relays on the bonnet slam panel are ? Could any of them be for the remote locking ? Or power doors cgv 2.8 2007 ? The reason I'm asking is after changing the radiator, and moving the panel , my auto locking and power doors are no longer working
  4. I used these , with the springs from the pins .
  5. Sorry my friend but if the idler pulley has came off, been damaged , whatever . Sounds like a lot of work . Had a pulley came off a Peugeot 205 diesel years ago . Cost me a rebuild .
  6. Fixed now , it was an intercooler pipe not connected properly and came off .now my key fob doesn't work . One thing after another with these cars .
  7. Foggy
    Radio code
    Hi I used this guy on eBay for my car . Cost £6 item 175516730327
  8. Hello.im looking for some help here . My 2.8 voyager auto has been giving me grief recently. It will drive about all day fine , but as soon as you boot it ( 70 or above ) the temp shoots up . Almost into the red .. anyway I decided to change the radiator as after a bit of reading it seemed like that was the culprit. Now it has 4 radiators , I realised the front 2 are a/c the one nearest the engine is the cooling one . The 2nd ( smaller one ) from the engine is water , but I've no idea what it does . Anyway after changing the main cooling radiator , the car starts no problem , drives away fine revs ok ,but as soon as the revs rise it has no power at all 0 - 60 50 seconds as soon as it hits a hill it drops the gear ok, but no power at all . I think it's either turbo , intercooler, or erg valve ( engine light is on , and erg fault code , but it's been that way for over a year. ) power loss is only since I changed the radiator , ps . I've driven it a good distance and as long as no hills it's not too bad , and temp is low ( 1/4 way up the guage ) . If I can get it to run better I'll do the radiator thermostat mod . Any help is appreciated.
  9. Hello Im not sure if this is the right section . But I bought a gv with no dvd buttons, anyway . Bought some from eBay and they work
  10. Found the problem ( to a degree ) if I activate the overhead door buttons it gives me the issue . If I turn them off , tailgate stays closed
  11. I had this with my last voyager , I purchased a creader CRP 123 code reader .it tells you what sensor is faulty ,IE left front sensor no reading . speed each wheel is doing while you are driving ,( if it doesn't read a certain wheel , it is obvious.) allows you to reset codes , a bit expensive, but any good garage should have similar equipment. I'm not a garage but mess around with a few cars and this has paid for itself many times over. I bought it when a garage billed me £60 to tell me an abs pump was faulty . And £150 for the reader. would save me in the long run. And it has
  12. I had that problem before with a different car , ended up using a suction mirror ( the type driving instructors use )
