nevo800
15 -
nevo800 last won the day on July 20 2020
nevo800 had the most liked content!
About nevo800
- Birthday 03/21/1968
ireland
nevo800's Achievements
Cheers forza for reply going to look into it cheers
ok a few items which i am hoping someone may be able to help with before i go to main dealer, anyone would be great 1. my reverse parking light has come on so reverse warning beep wont sound, light is on dash (P symbol with lines etc) prob need to get it fixed/changed but have tried WD 40 spray as featured on the oracle that is youtube to clean up sensor points on back bumper! any ideas if anyone had any quick fix or is it new parts etc anyone with experience of this 2. also anyone have any ideas on getting rid of flashing oil reset light (says change engine oil on dash) oil is fine as i changed it but my mechanic cannot reset it. 3. my mileage odometer keeps flashing on dash constantly is this a reset at main dealer after service? a lot of questions thank you in advance
Found Chrysler boot lock on eBay and perfect fits works like a dream problem solved boot locks, no dash light on. Couldn’t be happier.
Nello reacted to an answer to a question: Wont Close Boot
found a chrysler delta one so no probs thanx lads
apologies for another question looking for the punto bootlock does it have to be a 2013 one or can it be 2005? and is grande punto one different
Cheers nello thanx for all the advice great to hear it. Will look today for one.
Hi nello I pushed in the clasp on lock mechanism on the door to make the car think the boot was locked. The mechanism was pushed in so if you tried to close the door the clasp wouldn’t accept the lock as it was locked already. When I was finished I pushed the lock up again with the side of my key and the locking mechanism unlocked then I was able to close the flap but from then on the boot open light was on the dash. Not sure if I shorted out anything but the light in boot remained on so I removed it as battery drain but if I pushed down on boot physically light would go out both in boot and on dash but it still wouldn’t lock but when pressure taken off both lights came back on. Just wondering is it an easy fix that someone may know or an entire new lock needed and if so does it have to be Chrysler/lancia part or do Fiat bravo/ punto fit.
Cheers Ian will check it out
Cheers forza appreciated saved me a lot of time and effort as well as avoiding chancers
Thanx for the pointers great to get advice from people who had same probs.
hi after finally doing a bt of research can anyone help me out to see if these parts are compatible with my 2013 chrysler delta 1.6 multijet 120bhp diesel. i have read some very helpful comments here and although no replies yet i am thinking of buying these KYB FRONT COIL SPRING FOR FIAT BRAVO II 198 OEM RH3908 50707397 and KYB FRONT SHOCK ABSORBER LANCIA DELTA III 844 OEM 339785 50710404 has anyone any knowledge or experience. i know the last shock is advertised for lancia III but just checking.
ok have a problem my boot open light remains on dash and in the boot and wont lock when zap central locking, all four doors do lock but boot wont. Pushed in the lock of boot clasp on door to turn off boot light and ever since have had problems. The light will go off if i push down on the boot but stop pushing it and light on dash and in boot back on. It doesnt physically lock even pushing it down. I thought i may have messed with the clearance so applied tape to the metal hook the door locks into on car but doesn't seem to have any effect. have i shorted soething, moved something etc do i need a complete new boot lock or has anyone experienced similar. Cheers.
nevo800 started following Wont Close Boot and Wont Close Boot
did you ever get the shocks sorted on this as similar problem trying to source
ok guys same problem right front coil spring snapped on 1.6 120hp multijet diesel chryselr delta and trying to source front right coil and shock, looked on ebay and one seller only on Uk site chargeing £100 plus £25 shipping to ireland for coil. Bravo ones much cheaper and easier to source. Treat me like an idiot so bravo coil springs fit perfectly? do the shocks? Apologies once again just dont want to go ahead and order and tale of woe comes back from my mechanic who seems unsure. thanx in advance.
