vitasik
About vitasik
  • Birthday 10/17/1987
    Worcestershire
817 profile views
vitasik's Achievements
  1. Got access to Witech micropod2 ( which is allegedly newer version of starscan).... Absolutely same as with launch or autel. During initialisation pops out straight awayy with error : negative response: 0x22 Unable to start ESP sensor initialisation, error occurred reading from null null Swapped switches with my everyday run around 300c, same s**t. Then I checked wiring from brake pedal switch - all fine - It seems to have 2 channels - 1 for stop lights and can signal to release shifter from Parking, 1 for Yaw rate sensor and one for abs module. That last one makes or brakes +12v - all present and accounted for. So is cable seems intact to the abs module and not shorting to ground or +12v. Any suggestions will be much appreciated. I am running out of ideas. It will be shame to take it for parts as its in better condition than my everyday runner.
  2. Hi everyone. Can anyone tell me where the H*ll i can find dealer or independent garage that has genuine equipment to initialise ABS pump on 300c 2006 model. Anything that pops up on google in the 120 mile radius seems to be together with fiat and have diagnostics for vehicles above 2010, not before. tried looking up dealers mentioned in the original Chrysler booklet - none exist , one looked like massive digger went through it and is a construction site now. It needs to be dealer level as I tried with Launch and Autel maxis 908 pro, both have option to do it, both cant complete it even though pump module is new. Seems like there is issue on some 300c that can be done only by dealer. Anyone know any place ?
  3. Hi again. Sorry for not replying. Not in particular rush with it, had other things that needed my attention first.( custom sprinter with straight 6 diesel engine ) Anyway in the meantime tried several different diagnostics - Launch pro, Autel ds908 pro... Both suppose to be able to initialise the module. Both have option to do so and are trying to do it... Unsuccessfully. Autel gave a bit different error saying conditions are not correct. I did check stearing angle sensor read out and incline.. Both under 5 degrees, brake is not applied. Tried finding chrysler dealer or specialist.. . Lost that battle as well. It seems that when chrysler was bought by Fiat very few dealers remained same/kept equipment. Spoke with 3 places and they have everything for chrysler after 2010, but none have Starscan that is used before 2010. Anyone knows a place as close to Worcestershire as possible? Regards
  4. Hi gents, I like my 300c quite a lot, to the extend I bought another one with very low mileage for its age - 78k being 57 plate. Anyway long story short abs module has failed and it was replaced with new genuine unit from chrysler. Previous owner failed to initialize it. I tried with launch and failed as well. I tryed entering vin as well, but failed. There is no vin stored at the moment, so it is virgin. One thing strike me as odd - in errors it shows c107c and c107d, which is brake pedal switch 1/2 stuck. Can't see live data that would be different to my old 300c that I run everyday. Any thoughts?
  5. Hi Guys As I posted in newbies section few days ago and had no thoughts decided to make a separate post. My main issue is central locking misbehaving and I couldn't find my particular problem on google full stop. Unlocking from remote always spot on, locking it is another matter. No, its not the remote 100%!!!!! When you lock it from remote- it will enable the alarm, but will not lock the doors. Wont flash hazards as normal. After around 20 seconds if you press lock again - it does lock all doors and flashes hazards. So It cant be the lock playing up as well on one of the doors. What I did notice is that it stopped locking itself when at speed, even though its enabled in the menu. Any Ideas or somebody who has been there? Regards
  6. Hi Guys I am new to this forum, but not that new to 300c. Been driving it for last 18 month and done 48k miles ish. All Ok besides some annoying gremlins from time to time My main issue is central locking misbehaving and couldnt find my particular problem on google full stop. Unlocking from remote always spot on, locking it is another matter. No, its not the remote 100%!!!!! When you lock it from remote- it will enable the alarm, but will not lock the doors. Wont flash hazards as normal. After around 20 seconds if you press lock again - it does lock all doors and flashes hazards. So It cant be the lock playing up as well on one of the doors. What I did notice is that it stopped locking itself when at speed, even though its enabled in the menu. Any thoughts will be much appreciated
