dave555
    9
dave555 last won the day on October 24 2020
dave555 had the most liked content!
About dave555
  • Birthday 08/09/1968
    manchester
412 profile views
dave555's Achievements
  1. Hi I need to take lower cradle off for access to lower control arms,the drivers side bolt that goes into bush seems to be just spinning bush moves when bolt rotates you can't access it from behind at all just wondered if anybody had any ideas cheers
  2. Hi got a 2005 grand voyager 2.8 diesel,need to change front wishbone drivers side just wondered do you have to remove cradle or can you manage to remove it without thanks in advance
  3. Thanks for everyone's help on this I did it after a bit of head scratching the hardest part was the bottom 2 bolts on the bearing assembly as mentioned ,ant ratchet I couldn't get on then I realised if I remove the 2 bolts for the leaf suspension that were in the way ,and then put them back when I'm done which worked but found everything seized and rusted backplate s fell apart cos of rust so had to replace them and replaced the bearing cos they were seized on the backplate s but all done and got a decent handbrake lol oh and 1 caliper seized as well lol thanks again for everyone's help
  4. Hi does anyone know what socket you need for rear hub on grand voyager as I need to buy one as looks a big size thanks
  5. Hi trying to remove rear hub having problem for the 2 bolts at the bottom and everything is badly corroded as you can't get a socket straight on these wondered how other people have done it btw it's a 2005 grand voyager 2.8 thanks
  6. Hi trying to remove rear hub having problem for the 2 bolts at the bottom and everything is badly corroded as you can't get a socket straight on these wondered how other people have done it btw it's a 2005 grand voyager 2.8 thanks
  7. Hi thanks bignev for the advice not doing it for a few weeks ,I didn't realise you didn't have to remove bearing as the garage said you did,but they didn't want to do it from the sound of it and wanted silly money if they did lol
  8. hi my grand voyager failed mot on handbrake they said it needs new handbrake shoes plus pads and discs decided to do this myself ,my question is are the bearing assembly usely easy to remove as heard of issues with seizing up etc,i believe the handbrake is not adjustable and if problem with handbrake its in need of handbrake shoes,not worked on any chryslers before so just like to get as much information first thanks
  9. hi my grand voyager failed mot on handbrake they said it needs new handbrake shoes plus pads and discs decided to do this myself ,my question is are the bearing assembly usely easy to remove as heard of issues with seizing up etc,i believe the handbrake is not adjustable and if problem with handbrake its in need of handbrake shoes,not worked on any chryslers before so just like to get as much information first thanks
