dmal4ev
11 -
About dmal4ev
- Birthday 07/29/1985
Reading Berkshire
dmal4ev's Achievements
dmal4ev reacted to an answer to a question: New Member - Straight In With An Issue!
Hi all, just to join topic I’ve got similar problem but only need to put the cables back in the plug. What’s the order I need to put them? They are three cables: grey/white, grey/green grey/black. Any idea anyone? I’ve tried all 6 options of combinations but may have blown a fuse. Need to check this as well. Many thanks everyone
dmal4ev started following Park Assit Repair
Hi there, a month ago I replaced all bulbs on the heated seats and rear wiper buttons. I used led and they are still working fine. This is what I bought https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F163856940762 Cheers Dan
Gv Speakers Play For A Few Seconds Then The Sound Stops
dmal4ev replied to chrisdavisberry's question in Voyager 4th Generation (2001-2007)
I bought it from eBay: this is what you need: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F163787399651 I don’t know how to upload pics here, sorry. This is the one I bought, it’s from 2004 gv and mine is 2007, it doesn’t matter. There are all the same from 2001 till 2008. Just to be clear mine is not infinity sound system. Last weekend I removed the side right panel by the rear seats and the speaker to find the amp behind. Then I removed the amp and put everything back except the speaker so my wife can use the car with the kids. I left the cables hanging out so tonight I just plugged it to try. Hopefully this weekend I’ll find some time to remove everything again and put the amp on place. I can take a video and some pics for you to be clear what to do. Question is how to send them to you ))) Cheers -
Hi Kitulu, I’m new in this as well but for the past few months since I own GV I can say that all the noice and smoke from the aux heater seems to be ok. When I turn off my car it runs for about 2-3 min(I guess is some cooling stage) About your temp gauge sound like you have faulty thermostat, I guess it’s stuck open and the cooling keep circulating! Check your service history if the belt has been done recently. I usually do belt, pump and thermostat on my cars, although I haven’t done Chrysler yet so not really sure how is it. Cheers Dan
Hi there @@chrisdavisberry Our problem is sorted mate, it is the amp. I bought off eBay a second hand one for £30 and now my music is back alive!!! Just need to wait for the weekend to install it back on place. Cheers Dan -
Yes, they are around £10-15 I just want kid size because my little one is only two and adult headphones will be way too big for him. Do you think the sound to the headphones, goes through the amp?! As you probably know from my other post I have disconnected the amp and waiting for a new one now. Picture still runs tho. Cheers
Hi bignev, wiper works it’s just the jet wash, I guess I need to trace the pipe from the pump to the end to find if it’s a mechanical or leak problem. Thank you about your tips will keep updated the group. I have some feeling about the amp and I ordered one off eBay. Hope I’m right! At least will start from somewhere. Cheers -
Hi Chris, I have stripped the card on the right hand side by the rear seats and when I removed the oval speaker, I found the amp behind it,(god knows why they put it there). I’ve got it out but I don’t see any visual problems. There are two plugs which were firmly plugged, played with them in,out but no joy ?. I need to find now some information about how to check it. About going for aftermarket is an option but I personally won’t do it. There are so many other problems I’ve read while googling mine with aftermarket, sound as well, drain battery etc Also I just made my dvd playing back and if I sort the sound will be great. I had to started maybe with this that I bought the car just a few months ago and I’m experiencing lots of annoying issues. No sound, dvd not working(done this), no blower working(working on this atm), no light in most of the buttons, climate control, rear wipers, heating seats(done that) no jet washer on the back wiper....I guess there are many more I haven’t found yet. Cheers Dan -
Hi Chris, I’m gonna follow this topic as I’m having exactly the same issue with my 07 GV. I’ve read a lot about it but unfortunately there isn’t any suggestions for my case. I have standard radio and it’s not infinity. What’s yours? I guess I don’t have an amp, or have I? All fuses checked and everything seems to be ok with them. I’m going to strip the rear cards and check for amp because it seems to be something like loose connection. I don’t see any reason why would play sometimes and won’t others. Many thanks Dan
