ForzaLancia
    209
    23
ForzaLancia last won the day on March 27
ForzaLancia had the most liked content!
About ForzaLancia
  • Birthday 07/26/1960
    Birmingham
2620 profile views
ForzaLancia's Achievements
  1. There is a YouTube video on how to do thus on a 159, also works on the Delta. IIRC 1) turn ignition on do not start 2) push down on accelerator to the floor 3) press brake pedal seven times 4) accelertor on floor for a minute, do not touch brake pedal. 5) turn off ignition for a minute 6) start as normal and it shoukd have gone HTH
  2. ForzaLancia
    Oil leak
    what goes in those three bolt holes?They look very clean like something was removed
  3. Yep, done it on my 2.0, I used Sealey I think, about £30 off ebay but that was some years ago. HTH
  4. Looks good, I'd get some Lanoguard on that rear subframe!
  5. Hi, I think the part you need will be 51804489, but it does depend on what model you have. That seems to be for a 1.4 or 1.6 diesel. And it looks like it is shared with the Bravo. There a a few Delta being broken on ebay and facebook so you may drop lucky. I am not sure on the Delta as it not a failing I've heard of before but on the Alfa 159 the subframes rotted because of the plastic undertray trapping water. I imagine labour will be quite high unless you are handy with the spanners. Good luck
  6. https://lancia.7zap.com/en/del/tn/
  7. https://www.ebay.co.uk/itm/334633588401?hash=item4de9b756b1:g:V90AAOSwzCljeHPu&amdata=enc%3AAQAHAAAAsG8RIOx79lN6WZ5kMFoEPXUkv2AoFeFA%2BUf2JFf5ndLVfm4%2BwmG2OMuRPzE2w%2FJyCP0H3n7wrSVfV7gH8Bw62frf3XPVuCAxJb3M%2BRev4xxkimMIQ%2BCaqt5kt2kwfZ5w5hBc37179VMYyO51vIf76UuWeYx8BIWv63R3JEGUlmHwTpd9OzC65n762mKrX%2BurTRJLTOc3btEC6rhwiUxyC9bzp2RU7q0BT0ZjR6YLsUZc|tkp%3ABk9SR6Kc_4myYQ KYB are an excellent make, cheap ones also for £20 HTH
  8. your traction control is switched off or faulty. More likely the former, the button is on the centre console and around the same location as the heated rear window button, so it is easy to hit the wrong one. If it were a fault it is likely the ABS light would be on too as they use the same sensors to determine wheel rotation speeds. HTH
  9. Hi, David Evans off the Facebook Group. If the pic was from the back of the car I am sure that broken rubber concertina part is the handbrake cable gaitor! When was the autobox last calibrated? A long time since my two selespeeds but I imagine they re not that different but it made a big difference. No sure on the knock, could be anything suspension or steering related. Low oil pressure could also be from using the wrong oil or from a faulty sensor. There is AutoLusso in Bournemouth or Rusper Alfa near Haywards Heath who are Alfa specialists and will know the autobox as it is the same a Giulietta. Also Sussex Alfa in BN6. which may be nearer. HTH
  10. Hi, I managed to get my screen replaced with AutoGlass. It did have to be specially ordered rather than off the shelf as my car has the sensor for the auto light. They did bring along the one for cars without the sensor first time round, so there is at least one in the country. AutoLusso in Penrith will be able to do the auto box easily. A well respected Alfa specialist will have all the kit to do the job properly as it is the same box as fitted to the Giulietta. The clunk may be a concern though as these boxes suffer from wear on one of the bearings. There are YouTube videos on what to looks for (on a Fiat 500 IIRC, same box), often specialist put an extra 500ml of oil in the box and that seems to sort it. My box has 150k miles on it and no sign of a problem (unless it explode on the previous owner!) Cambelt should be easy, the engine is the same as a Vauxhall Astra/Vectra so any garage should find it pretty easy although they will doubtless try to charge you an extra £100. Or simply take it to Autolusso who will do the water pump at the same time. HTH
  11. yes, same as Bravo, Giulietta and 500, IIRC Gates is the OE supplier to Fiat, so not sure why he would not like them......
  12. ForzaLancia
    paint code
    Hi, and welcome the paint code is on the underside of the bonnet near the leading edge, so you have to lift the bonnet right up to see it. HTH
  13. Powerflex do poly bushes too, limk below https://www.powerflex-shop.com/Powerflex-Polyurethane-PU-bushes-for-FIAT-BRAVO-II-198 HTH
  14. an SR is the one to go for, you get alcantara which it seem special. The top of the range is all leather which is not to special, could be off a VW! and it is not as pliable making the seats firmer. Most of the rest of the toys are the same. I can only speak of my car but it has been very reliable, whereas the Mercedes van I use at work is half the age, half the mileage and is a bag of crap. Also on my Alfas any faulty part usually has Bosch stamped on it, so a Delta is a step up from VW. HTH
