leeoliver2010
26 -
About leeoliver2010
- Birthday 06/04/1979
lincs
leeoliver2010's Achievements
QinteQ reacted to an answer to a question: Gearbox Service 2.8Crd Auto
2.8 Crd 2006 Auto Gearbox Lost Drive....
leeoliver2010 replied to Treacle's question in Voyager 4th Generation (2001-2007)
Mine went at same time as yours mate its torque converter I think so it's a whole rebuild have you had it done yet -
Just changed my abs sensor on front right was realy easy as long as bolts don't snap as mine did lots of lube and ebay sell Danso which is on for £25 so I'd change both fronts rather than 1 you could easily do it without taking wheel off I reckon
leeoliver2010 replied to Dazandtrace's question in Voyager 4th Generation (2001-2007)
I'd use the best parts you can get we just had our gearbox fixed to the tune of £2200 tho we were been taken for a ride as tinda lee were adamant that a 2.8 crd has a 6 speed box in it and I know it's a 4 speed box it went in with a niggle before box stuck in gear and having been told rebuild included sensors ect it didn't, is there any trust left in garages anymore to make matters worse there health check reported low oil, it wasn't, low tyre tread... They wasn't they originaly said £3000 all in I did lots of research and found other places were 1500-1650 so I complained did my homework and got them down to £2200 having found receipt from gearbox fluid change they had used ordinary fluid not our recommended oil I believe this is what killed my box -
Reseting Engine Codes
leeoliver2010 replied to leeoliver2010's question in Voyager 4th Generation (2001-2007)
No light and codes remained -
I took off the black cable for nearly an hour when I put it back on radio didn't need code and even remembered it's pre set settings -
I've heard you can manually reset codes by holding in trip button for period of time is this true anybody know I have code p1130 and code p1685 I've changed both fuel filters so far, wondering if the 1685 code for security is linked to my power door not working but I doubt it
leeoliver2010 started following Memory Seat Positions On 2.8 , Reseting Engine Codes , Engine Code 1685 and 1 other
Did the key test and had 2 codes stored 1685 and 1130 just changed both fuel filters, I'm wondering if code (1685 related to security) is linked to fact my back door has started playing up it only opens electricly half way and only shuts half way broken wire I'm assuming but wondering if it's linking the engine light code 1685
Engine Code P1130 - Voyager 2.8. 55 Plate
Are they easy to change or is it best to get garage to do it? Any idea on £££s -
leeoliver2010 posted a question in Voyager 4th Generation (2001-2007)
I went away for 2 weeks came home and fuelled car up on way home from airport, after 5 or so miles engine light came on after few days went out didn't put me in safe mode or anything then after a week put more fuel in and again light came on this time for week or so key dance code p1130 light went off for a day then back on car running fine tho -
Front Discs And Pads On Grand Voyager
Kwik fit wanted just shy of 300 pound and they use low brand brakes, gsf were doing brembo discs/pads but they were double the 90 quid price I thought apec were alright brand wise I have them on my mazda rx7 and there able to stop that -
I brought front apec discs and apec pads they were £90 from allwoods and got pit stop to fit them, they charged £30 quid to fit parts and 25 to read abs code -
Is that the over head thing that does the Mpg and all that stuff -
Hello people I recently had my discs are nd pads (front) changed and abs code read since then they've turned abs light off by removing or reseting code but now my memory seats settings won't work if you press them it just says driver 1 or 2 in the radio box it's puzzling me
Air Con Compressor.
leeoliver2010 replied to Eyore28's question in Voyager 4th Generation (2001-2007)
Gsf did 1 for my voyager 300 notes wouldn't buy second hand 1 they will have air and moisture in and will not work when you buy new they come prepared oiled and vacuum sealed
