lessuth
    24
About lessuth
  • Birthday 05/13/1946
    australia
1976 profile views
lessuth's Achievements
  1. A cracked flexplate will cause the engine to go into "fail safe" and will not allow the engine to rev past 2K. A check can be done thru the inspection port of the bell housing to see if the flexplate is cracked
  2. I'm wondering if the workshop used a transmission fluid other than ATF+4. Suggest you have the pan dropped to see if there is any metal from a transmission failure.
  3. Hello, can anyone tell me is the bolt pattern for the 62TE transmission the same for the 3.8l motor and the 2.8l motor? Cheers
  4. can anyone tell me if the problems suffered with the heating element in the 2.8 fuel filter has been carried on to the RT series. My 2008 is behaving just as if it had a fuel leak like my 2006 had. Also where exactly is the fuel filter located. I can't see it in the front just above the starter motor as it was in the 2006. A picture of it or part number would be great too Thanks in advance
  5. hello, can any member help me with the part number of a rocker cover gasket to suit a 2008 rt 2.8L motor. Also a supplier name and email address would be appreciated. Cheers
  6. Hello, I'm hoping a member may be able to help me with some part numbers for the engine and transmission mounts to suit a 2013 RT 2.8 L. front, back left(transmission) right and the isolator mount this is the isolator mount this is the transmission mount (note the offcentre mounting holes) the back mount is bigger than the ones used in the 3.8 petrol version any help locating a supplier would be also be appreciated
  7. Hello anyone able to to tell me what a 62TE trans weighs inc. torque converter? thanks
  8. Does your slight miss normally happen when you are starting off and if you remove your foot from the pedal and reapply it the miss has gone? Are you sure the trans is slipping? Could it be a manifestation of the "miss" as the engine does not stall but just seems to "starve" for diesel? These diesels seem to need a minimum of 650 CCA to 800 CCA and have a good charge rate or can behave in the manner I have just described. I have seen the fuel pressure regulator valve give a similar fault.
  9. my understanding is that it's the third relay from the left, mounted on the crossmember (in front of the radiator)
  10. I think your 2010 Voyager has a 62TE , six speed transmission whereas the subject mentioned above was relating to a A604/41TE 4 speed box.
  11. update, I have just relocated the vehicle. 1400 kl road trip still with no reverse yet it traveled perfectly in all forward gears. Go figure!
  12. @Stevom I'm hoping I don't have to do a complete recondition
  13. thanks for the info Stevom. Can you recall the code you were getting or where the fault was in the box?
  14. 2008 3.8 with 62TE transmission just out of the blue the reverse gear quit on me. All forward gears change smoothly but will not go into reverse. Any suggestions please?
  15. Thanks for the reply bignev. In 2005 with the introduction of the NGC they relocated the PCM to a spot beneath the splash guard up inside the left hand mudguard. I'm wondering if they are more forgiving in the newer version with compatibility ?
