Italianstallionxx
    14
Italianstallionxx last won the day on August 15 2018
Italianstallionxx had the most liked content!
About Italianstallionxx
  • Birthday 06/01/1968
    Worcester Park
494 profile views
Italianstallionxx's Achievements
  1. Hello all I have a 2007 version, but there is no filter at rear. Ive changed the one on the engine but nothing found at rear, not even a mounting bracket should someone previously think to get rid of it. My question is......does it exist ????
  2. Well took it apart,as yes I found three broken wires,and omg how hard they had become.....no wonder they broke
  3. hello all, I've seen the posts but just wanted to make sure before I take it apart. My electric sliding door when i push the button, will only open about an inch then stops. If I push it manually about an inch and push the button, it will then fully open. When I push the close button, It will close but stop about an inch from the end where I need to pull the rest of way shut. Everything was fine until other day as it was closing, I took key out of ignition mid flow so to speak, and now I have this fault. So I thought maybe by interrupting things I had wiped its memory of the open and close points and so had to re-teach it somehow, or wad it just coincidence ? Any suggestions ?
  4. Hello all Just an insight into my saga. One of my front top bushes collapsed, so I thought I would replace my self, being a mechanic I thought no problem. Oh my f#@*ing god......how wrong I was. The problem....... compressing the spring. I have a professional tool that couldn't do the job. I went to several other garages to see if their tool could do the job, and they couldn't, and some said they wouldn't try as the car had developed a reputation of dangerous/stay clear of concerning these springs. Finally I found a garage that worked on vans and mini buses who was willing to give it a go........ 40mins later ..... he said omg ...... he had never come across a spring as bad to do as mine. Seriously !!!!! I can't believe it. Car still not finished as ive had enough. There is no value in my comments today but equally if I found a comment like mine.... I would of purchased a complete assembly, of which I've seen for sale and spared myself the heart ache. I did think at the time a false economy to buy complete assembled strut but I know better now.
  5. Hello all, just spreading some knowledge. When I bought the vehicle the rear was not working. After extensive googling and looking at manuals, I was getting no where. Bottle full of water, pump making a noise, jets not blocked, but still no spray. So I decided to rip apart the car. Found culprit. In the boot under carpet there is a plastic straight connector. The tube had come off and filled boot with water. Looms and carpet all green, rust beginning in floor pan, no explains why there was a strange smell in car. Problem solved. Now have to work out how to kill the smell ??????
  6. thank you for that. so is there just the one filter by the fuel tank ? and yes its a 2,8 diesel
  7. hello i have a 2007 grand voyager, when does the fuel filter need changing as the only reference i can find is every 20K, which cant be right, and how many filters are there to be changed. thank you
  8. Hello all, just got a 2007 Grand Voyager. Couldn't be bothered to do job myself so gave it to my local garage. Timing Belt Kit ( 3 year warranty ) + Water Pump done for £640 all in. SWB Autos in North Cheam, Surrey Im happy
  9. Ok So as for the voltage readings,why could I not get a reading ?
  10. Ok So as for the voltage readings,why could I not get a reading ?
  11. Hello Just wanted to know how you test an electric feed on 2007 Grand Voyager Exec X'S. My sliding door actuator had given up. I put a test light on it and nothing lights up I put a multi metre on it and no feeds when I use the fobs. But I know there is a feed there as the actuator twitches a bit,nit enough to lock the doors. So.........how do I test for feeds apart from buying new actuator and fit it......an expensive path if it's not that Help much appreciated
  12. Yes its a diesel. Always had cars that could source parts fairly easily from somewhere. Hope I not made mistake work this one ?
  13. Hello all Just bought 2007 grand voyager. Where do I get new parts from,I'm looking for a high brake light lens for starters but there are other little cosmetic things too. Everything I find is used parts from eBay and not everything I want is available even as used
