Stealth1hunter
Stealth1hunter last won the day on June 1 2018
Stealth1hunter had the most liked content!
About Stealth1hunter
  • Birthday 09/18/1970
    Uk
Stealth1hunter's Achievements
  1. Not sure if u got this sorted. I had the same problem with starting. Changed battery all was well for a few months then back to bad starting. After some more investigation i found oil was dropping onto starter motor. Starter motor bushes burned out.... bought new starter £120 sorted... 4 months later foun d you can buy bush set for £15 on ebay
  2. Have a 2.8d 2005 After a drive over 65mph the car has a slight misfire on tick over.this then stops after a little while and all is ok. If I drive under 65 it NEVER HAPPENS...THANK YOU INADVANCE
  3. If you rev the engine does the noise go an come back when you De accelerate if so i can 100% guarantee that it is the decoupledr pulley on the alternator. You can buy these on line.. I changed the tensioner first DIDNT NEED IT THOUGH... that seemed to work but not for long a week maybe....DECOUPLER PULLEY also called a clutch pulleyhttps://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F263281585361
