8953lewis
33 -
8953lewis last won the day on March 12 2018
8953lewis had the most liked content!
About 8953lewis
- Birthday 01/14/1966
8953lewis's Achievements
frogland reacted to an answer to a question: Grand Voyager 2007 2.8 Crd Auto Exec Gearbox Ok?
8953lewis replied to GavinG's question in Voyager 4th Generation (2001-2007)
Hi Shifting to 3 is safe at speed it's a bit like using the kick down but using L I would advise from stationary as it uses 1st gear for a long time then shifts to second. It's almost like a get you moving gear but not at speed. -
What car are you selling as you don't say ?
3.3 Petrol Won't Crank
8953lewis replied to Andrips's question in Voyager 4th Generation (2001-2007)
Hi Definitely the battery had very similar problem new battery fitted never had a problem since. Turns out battery had just died due to being quite old charged it ok for a few days then same thing again rac confirmed battery. -
karmannski reacted to an answer to a question: 2.8 Crd Engine Is Cutting Off
8953lewis replied to karmannski's question in Voyager 4th Generation (2001-2007)
Hi all Been having similar issues with starting first thing then once warm an absolute pig to start. Tried 5 maybe 6 goes to get the engine to start until today and as many previous posts changed the fuel filter & hey presto starts first time every time old filter was clogged with what I can only describe as gunge also had the engine decarbonized & not sure yet if it makes a difference only time will tell. -
Hi Found this on eBay item number 152698555077 hope it helps only £11 including 3 sets of head phone's Mark
Pollen Filter Replacement
8953lewis replied to 8953lewis's question in Voyager 4th Generation (2001-2007)
Thanks for the replies all.sorted now sourced a comline ekf351a pollen filter perfect fit. Job done? -
Hi all I have a 57 plate 2.8 crd & want to change the pollen filter inside the cabin. I know where the filter is & how to remove it but the problem I have is replacing the old filter with a new one. Which filterbis the right one? I have measured the old filter but on eBay & Euro parts the filter they say fits is a different size someone please help me. The size fitted is 301 x 200 x 23 the one they all say fits is 308 x 236 x 23.
2.8 Crd P0235 Code And Other Stuff.
8953lewis replied to frogland's question in Voyager 4th Generation (2001-2007)
Hi I'm sure there was a post on here with similar issues turned out to be the fuel pressure regulator valve. Got to be worth a shot rather than spending hundreds getting the injectors checked they are about £40 on good old eBay. Mark -
Need Ac Condenser 2006 Gv 2.8 Crd
The item number is 281285838679 priced at £79.50 with free p&p sorry couldn't fit it in my last post. Mark -
Hi i found this on ebay Brand New, Excellent Quality, Boxed Chrysler Grand Voyager / Voyager Complete Air Conditioning Condenser. Fits: Chrysler Grand Voyager - 2.5 CRD diesel / 2.8 CRD diesel - MK4 - RG / RS - 2004 to 2008. Chrysler Voyager - 2.5 CRD diesel / 2.8 CRD diesel - MK4 - RG / RS - 2004 to 2008. Suitable for: Chrysler Grand Voyager automatic vehicles, with air conditioning. Chrysler Voyager manual and automatic vehicles, with air conditioning. Useful information: Our part number - 16CND1999A. Original Chrysler part number(s) - 05142490AA / 878003 / CA1476. It should be the right one. -
ametcalfe1989 reacted to an answer to a question: In Line Thermostat
I just bought a syphon pump from halfords £3.99 (hand pump one) empty the header tank first then do the thermostat.
Would recommend to anyone with a 2.8crd do both the fixes it definitely works. Thanks to Andy for the detailed video well done.
Hi all Did the battery mod & in line thermostat fix 2 weeks ago. Wow what a difference especially the battery mod starter whizzes round on a morning & car starts much quicker & thermostat fix puts the pre heater light out so much sooner
Anyone Did A Egr Delete On A 2.8Crd?
8953lewis replied to GVCamper's question in Voyager 4th Generation (2001-2007)
Well I was only going by the description & that said has a 10mm centre hole to fool.the ecu in to not throwing up any codes. If that works on not I don't know but would be intrested to find out. -
Hi Did you get the one with a small 10mm hole in? As that says no codes thrown up as it fools the ecu.
