Dansail
    11
About Dansail
  • Birthday 05/12/2001
    Holland
Dansail's Achievements
  1. M10 is for the radio/dvd nav handsfree. It should be a 20A yellow fuse. Did die once in ous
  2. Is this only at startup? I have a 10s misfireing at cilinder 1 (3.8) at cold start and after that all is well. Seems like spark plug in my case. But have you checked oil pressure and air and fuel intake?
  3. My trip computer telling me my average mileage is correct when running petrol, but slightly off when driving on LPG. But the numbers posted are all miles driven/litres consumed measurements by hand. The 2001 didn’t even have a mileage computer so all by hand. I am surprised though that the old voyager with a 2.4 was consuming more than the new voyager with the 3.8 (much heavier and a bigger engine)
  4. There are three bolt in mount points on which the rail bolts to the roof
  5. The newer ones only come in automatic, i have driven tge 3.3 and 3.8 from the 2008 model range, 3.3 averaging 11.5 l/100km and as i said before 3.8 on fuel 10 l/100km or bit better. 2001 2.4 manual would do 12 l/100km
  6. Oem add on wil cost you hindreds of dollars, better fit a complete aftermarket infotainment screen ( kenwood) foor 500 dollars
  7. 3.8 v6 lpg full spec will do 7.5km/l on lpg little over 10km/l on petrol. Though i think i got lucky here, as i read much different numbers from other people
  8. You can turn the sound on in the evic in your dashboard. Its a setting, cause if you have a towing hook the sensors keep beeping
  9. The metal cutout wouldnt start the car, cause it doesbt fit. Opening it will turn on the alarm, which will stop once you put your keu fob in the socket en turn to on. 20 dollars on ebay will give you replacemebt key, wgich you can simply program yourself in 2 mins
  10. I have one with roof rails and bars, will take a look
