Adamalzo66
10 -
Adamalzo66 last won the day on February 1 2018
Adamalzo66 had the most liked content!
About Adamalzo66
- Birthday 07/14/1994
Manchester
Adamalzo66's Achievements
White Smoke On First Startup In Morning
Adamalzo66 posted a question in Voyager 4th Generation (2001-2007)
Hi guys and girls i have a chrysler grand voyager 2.8 crd diesel 2005 recently when starting it up in the morning it has been puffing out white smoke with a diesel sort of smell from the exhaust and then clearing up im not sure what it could be fuel economy has gone worse but i think that might be due to the heater being on all the time any ideas guys for the smoke is it normal ? it clears up after a few seconds and it does not do it till left for a day or so any ideas would be apreciated cheers -
Chrysler Grand Voyager 2.8 Crd Starting Issues
Recently i have had issues with my 2005 cgv 2.8 crd with starting i love this car but starting is a mayor issue with mine currently. It struggles to start in the mornings if left for hours i bought the battery 7 months ago so i do not think the battery is finished yet i can get it starting by charging the battery but if i try just starting it it cranks for 2 - 3 seconds and dies a couple of weeks back it left me stranded outside the school the starter locked up i managed to hit the started a couple times and it started right back on but im not sure if that has anything to do with the battery draining and after i charge the battery the car starts with no issues any help would be apreciated cheers. -
Adamalzo66 started following Looking For New Alloy Wheels For My Grand Voyager 2.8 Crd
Cheers both you guys i will check behind both wheels for any loose connections like i said if it does not seem to have any problems i will take it to a local garage to get it diagnosed thank you guys for all the help
Is the driveshaft bolt easily accessable after taking off the wheels because i have a little knocking noise when turning the wheel but i have not paid attention to it due to it being minor you recon that has something to do with the problem ?
Mike thanks for replying its both trac off and the brake light on i was thinking off buying a bluetooth plug in code scanner of ebay they are relativly cheap and would be a good investment to use on other cars i will give all the connectors on both sides of the front wheels an inspection and i will see from there thanks for the help
Mike i do believe my sensors are bad i did some research and apparently its a common issue for them to wear out or become loose i will give them a clean this weekend and check for any loose connections see if that fixes it if that does not work i will get it plugged in before buying replacement sensors What side wheels shall i check ?
I was looking around ebay and im thinking about buying these https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F332502727544 Before taking the wheel off if any off the sensors are broken i might as well replace them while im at it are these recomended ? And what wheel what side do i replace thank you
Thank you guys very much i recently have been busy this weekend i will take off the 2 front wheels and check behind the brake discs for any loose sensors and clean any dirt and try fixing any loose connections if that doesnt fix it i will shop around for some wheel speed sensors any cheap ones that will do for now if that does not fix it i will have it plugged in by garage and check the codes i will update you guys asap thank you very much
Hi guys im new to this forum i bought my parents a chrysler grand voyager 2.8 diesel a couple weeks back its a very nice car i got it for cheap but it had one issue the hand brake light is on and the odometer says " Trac Off" today we had a little snow and the tires started slipping when i press the trac off button on the steering column nothing changes i believe that there is a problem with the traction system correct me if im wrong any help would be appreciated guys cheers
