Cassino
44 -
Cassino last won the day on November 7 2020
Cassino had the most liked content!
About Cassino
- Birthday 02/21/1944
Hampshire
Cassino's Achievements
9
I don't think LEDs are legal in the UK......yet. I have put LEDs in the glove box,and boot light...I don't use the fog lights enough to really need LEDs.. Ian.
2012 1.4 Delta - Won’T Accelerate Uphill
Cassino replied to sheffieldcelt's question in Chrysler Delta
Your mechanic should have first put the OBD engine analyser on,to check engin4 faults.....that should tell you everything.. -
I have dinged my bootlid,glass has gone......Anyone know of a breaker with one for a 2011- 14 Delta.....in the south east would be good. Thanks Ian
Reeko,always bear in mind that items such as your door/boot locks will be from the parts bin from Fiat, Alfa, etc.stores, so check out used parts from breakers, and cars such as Late Punto, 500,Bravo, MiTo, Guiletta...etc. If it is like the boot lock, there is a micro switch built into the latch, so you may need a new lock......As I recall, I snagged a genuine Fiat part for a 2006 Punto for £19.00 . Or it just may need a good clean.... Good luck. Ian
dave reacted to an answer to a question: Chrsyler Ypsilon Parts?
I replaced front discs and pads a week or so back..... Advisory on MOT in May 2019 suggests that the inner faces of discs were flaking.So it was well overdue,pads had about 5-6 mm left. I fitted Unipart discs(£28),and Juratek pads(£21) from the Bay.....be aware that Juratek pads have only one wear sensor...part number JCP 1468. Just returned from a week in Devon, and those improved brakes were very welcome ,steep hills, very narrow lanes etc. Ian
Cassino reacted to a question: Brake Pads/discs Recommendations
Cassino reacted to an answer to a question: Looking To Buy
I think the boot lock (if it's the same as Punto)may be your problem....take it out,clean and check it.....I got a new replacement (genuine) for about 20£ for my partner's 2006 Punto. Fitting is a doddle.... Ian
I thought it strange, but I noticed that I don't have one......
I have never needed to adjust my headlights,but there is a switch on the dash for adjustments.... As for the bulb changing,it is a pain especially the offside one, but we should be grateful it's not a dealer job.....some can cost £150-250.... Ian
Nello reacted to an answer to a question: Chrysler Delta Battery
Yep,I forgot about the steering error bit....simple fix...thanks for reminding us Nello. Ian
Cassino reacted to an answer to a question: Chrysler Delta Battery
I changed mine about a month back (2011)......no problem, just re.set your date time etc.
Cassino reacted to an answer to a question: Front And Rear Discs
Cassino reacted to an answer to a question: Confirmation It's Italian
If it were my car,I'd consider buying one of those Syphon type devices.....leave the plug in place, make sure the oil is really hot......(which I always do, and I leave overnight for a proper drain)and suck out your old oil... Ian
Cassino reacted to a question: Confirmation It's Italian
And the same to you and yours..........
vincey832 reacted to an answer to a question: Auto Lights
1.4 140Hp Limited Torque And High Fuel Consumption
Cassino replied to kapetanikolas's question in Chrysler Delta
Would there not be a dashboard warning (engine light) signal if sensors,leaks or any other failures occurred?.....just a thought!. Ian -
Are you going to do the belt change yourself?...... My belt is on 54k.....I took a look at it and it looks fine....but at 111k,yours had done superbly well.
I think discs on cars now are maybe softer than of old........my discs have done about 55k, but have been flagged up on MOT as advisories to replace. On close inspection a few weeks back I detected a rough corroded high spot on the back face of one side of the car. I will replace them and hope the braking will be better,as I would like more "bite" as I feel they seem to be a bit under servoed so to speak... Iv not driven any other Delta, so I don't know if mine is normal for model?
