Foggieloon
Foggieloon last won the day on October 23 2017
Foggieloon had the most liked content!
About Foggieloon
  • Birthday 04/13/1952
    Scotland
Foggieloon's Achievements
  1. I have a 2011 grand voyager limited. Today I attempted to start the engine as normal and nothing happened! The electrics were all working and the gear shift was stuck in park! I waited for a few minutes then after a few more attempts the engine started. What could cause this to happen? The car was in a garage recently for reversing camera issue( not fixed) They found fault codes P0562 and P0850 Could this be related? Any advice would be much appreciated.
  2. I have a 2011 Grand Voyager. It has a faulty reversing camera. It has been checked by an Auto Electrician and he has checked all wiring ok. He has told me a replacement camera from Chrysler will cost £500 Is there any way I can source the camera a lot cheaper and has anyone attempted changing the camera? A guide would be much appreciated.
  3. Hi Mike, The vehicle does not go into limp mode. You may be right about the sensor. It may be worth purchasing a new sensor. Is it a pig of a job? I have a workshop manual on cd and a haynes manual. cheers
  4. Hi Mike, Thanks for the fast response. The vehicle is a 2.4 manual petrol. I have attached the garage report and it seems they they have checked the sensor? they also supplied me with known fixes for this problem also attached
  5. Hi everyone, I have a 2007 2.4 Executive Voyager in black. The speedometer is not working but all other gauges are working fine. It is not the needle at wrong side of stop problem and re-calibration has no effect. My local garage has had a look at the issue but they were unable to rectify it. They ruled out sensors and fuses! Is there anything I can check without incurring heavy garage charges to trace the fault? My electrical knowledge is somewhat limited and any clear guidance in this matter would be much appreciated.
