PaulHammond01
11 -
PaulHammond01 last won the day on September 16 2017
PaulHammond01 had the most liked content!
About PaulHammond01
- Birthday 04/10/1977
Nottingham, Ollerton
PaulHammond01's Achievements
Take a look on eBay or pt company, ask for a guy called Pete. Also what car etc ? Paul
Just found you by chance, that's it. Will see how it goes. Seems a little quiet though,
PaulHammond01 started following New 300C Owner :-) , How Did You Find Us? and New To This
Hi, if you wish to put picks up, go back to the main topic screen, where people have posted what they want and second one down, tells you how too post a picture. Paul
Welcome. I am a fellow Crd owner... I have had my 300c Crd Touring for around 9 years, and not once have I ever wanted to get shot of it. Love the road presence it has, the size and some power when you need it. If you have any problems, I will help with what I can. They are a pretty good car to work on. Paul
You can to the glow plugs your self, look on you tube it will show you and buy the plugs of eBay, can't fault any of them at all. As for the Abs, check the ABS sensors or with a vault meter, also I had the lights for the ABS on for over a year and it ended up being the main bolt that holds the axle etc all in place, my garage just tightening it and it was all sorted. I have heard of other things regarding the ABS lights such as a cable which runs under the car and over the years it rubs on a A/C pipe and wears that cable down. Just a little bit of insulation tape will do the job. Regards Paul
mikebh8 reacted to a post in a topic: Abs/bas Traction Control.
Good news. Whilst my car was in the garage and the hand brake set up was being done New hand brake cables, discs, pads and fixing kit. I asked me mechanic to check a couple of things whilst he had it all in bits and he discovered that the main nut that was holding the rear drive shaft on, had come lose (wow). So whilst it was moving around the sensor was not in line with the CV ring and was not reading it, and was always giving am intermittent problem. So all solved and no orange lights on the dash, cheap and cheerful. Thanks for the advice. Paul
Inhibitor Switch For A 2009 Chrysler 300C Touring
PaulHammond01 replied to jeananddonal's topic in Newbie Forum
Hi, silly thing to say but have you attempted EBay, I have had good look with that for my Chrysler parts and have had no problems, you could also try a company called PTcompany I have had many parts from them, the guy that I deal with is called Pete follow the link and take a look http://www.ptcompany.co.uk/ Or http://www.chrysler300cstore.co.uk/ Hope that helps at all. Paul -
I shall also give this a blast and see what it States, when I took in for the MOT he put it on the computer and said its passenger back which is thee problem, so monday/Tuesday will be another day of finding out. Thanks again Paul
Thanks for your reply, I shall get the garage to do this on Monday/Tuesday when it goes in. Anything is a help to get this little issue done. Paul
Hi mikebh8. I have the same problem as above and reading your reply to the above gent, you mention the wheel is off angle. Please may I ask what you mean by this ?. Paul Nottingham
I have a Chrysler 300C CRD Touring 2006. I have had the above mentioned lights on my dash for over a year and now I need to sort it. I have changed the wheel speed sensors on all four wheels, it went away for a while, then cane back. It is very intermittent for the lights. I am changing the CV O rings on Monday, if this doesn't work I would have to change the ABS module,, which is a last resort, as it's San intermittent problem and if it had gone it would be on all the time. Talking to a friend he stated that some cars when the hand break is none existent and the rear brakes are ready for changing this light can cone on. Had any body else had this problem?. If so please help as its doing my but in and I do believe it is something simple.
