alfaspud
    74
    12
alfaspud last won the day on June 14 2020
alfaspud had the most liked content!
About alfaspud
  • Birthday 05/29/1977
    Ireland
alfaspud's Achievements
  1. alfaspud
    Rain leak
    Hi all, I have a water leak on my 2012 LTD. Headlining at the rear on LHS just inside the tailgate is wet. Presume it is rain as the rear washer jet is still working. Had a look but couldn't see anything obvious. Put a bit of silicone around the tailgate hinge mount just in case but rain still seems to be getting in. Does anyone have any suggestions? Are the rubber strips on the roof clipped in or are they just in a sealed trench? Just wondering if there are mounting holes underneath it. Is it difficult to remove if necessary? Cheers Delta brothers Belated happy new year
  2. alfaspud
    Sun visor
    My driver's side sun visor is hanging down - won't stay in either position - either against headlining or towards windscreen. Have to swing it to side as it is just flapping in front of my eyes. No resistance to hinge mechanism at all. Anyone ever experience this and any advice on a fix? Had a quick look but I'm stumped Have looked at replacements but they're either mad money or in rag order or both
  3. Thanks Mike. Will give it a go if the rain ever stops here
  4. Anyone actually removed the door card? My internal handle has stopped opening the door so I have lower the window to open from the outside which is a pain in the arse. Presuming the linkage has come off between handle and lock. Any advice about taking the card off greatly appreciated
  5. Just had a look at mine there - no unused plug visible behind either flap that I can see Reversing light present and correct too Not much help I know but stick up some photos and one of the more experienced guys will be able to sort you out The unit itself may be the same as on a Grande Punto - looks very similar to my eye but I'll check when I get home
  6. Is that 12v when reverse is selected?
  7. alfaspud
    Egr Valve
    Need photos of the Marea asap
  8. 10 miles doesn't sound too bad Mine is out by at least 100km - I was driving in the Irish sea for a while - I think the GPS aerial is the problem with mine - no satellites found I have the same issue with the tyre pressure system - especially on cold mornings, I usually get a warning for 1 or 2 tyres - read somewhere that the batteries in the sensors may be running down No problems with the bluetooth so far
  9. damned if I can find a drain hole - anyone else know where it is?
  10. Sat nav isn't touchscreen (mores the pity) - not the OEM one anyway
  11. you could be waiting a while.......
  12. Definitely not condensation in my case - pool of water under the plastic insert when removed You'd want to be dogging all night, every night to generate that much moisture
