frogland
    106
frogland last won the day on June 25 2018
frogland had the most liked content!
About frogland
  • Birthday 04/02/1971
    France 13
frogland's Achievements
  1. Thanks QuintQ for the quick reply ! Whereabouts should it be fixed ? On the bumper ? Thanks again.
  2. I recently removed the font bumper for repairs and found this sensor hanging down. Can anyone tell me what its for and where it goes? Thanks.
  3. The AC clutch relay has been removed,an the cable goes through the firewall to a switch inside. I don't use th AC so I haven't bothered with it.
  4. Do you mean the A C clutch relay,that's in the fuse box ? The previous owner has made some kind of modification in that area here are some pictures :
  5. Sorry but I think you need to start a new topic. But it's likely to be a fuel issue they're quite common with this vehicle.
  6. The coolant fan starts and stops all the time ! There are no temperature issues and i've been driving with this issue for a few thousand miles. Relay ? If anyone could shed any light i'd be interested.
  7. I cut the battery tray and fitted the biggest battery I could find- it helps !
  8. I'd like to install a fuel lift pump to give the IP a hand,has anyone done it,has anyone of any ideas,how easy/difficult should it be ? What pressure rating should it be ? Where abouts should it go ? Thanks.
  9. P0235 (boost) the turbo and EGR are fine and i've replaced the MAP sensor.
  10. Mine as been starting a bit better first time in the hot weather but if i cut the engine and then go to start again it can be difficult I wonder if vapour pressure in the tank has any influence ?
  11. yes exactly this low fuel pressure problem crops up all across range range of models fitted with the crd. Im thinking of something along these lines : https://youtu.be/BCZR1b-ptXs
  12. I was just about to ask if anyone has added an inline fuel pump to their 2.8. Yeah the primer should be hard all the time. I've just replaced the fuel filter housing/primer with the new updated one and there's still a fuel pressure loss problem going on. A lot of people on the lost jeep forum suspect dodgy fuel pipe connections in the fuel tank region. so a lot of them have resorted to an in line fuel pump either in the engine bay or near the tank,I suspect on our cars it would be easier to do it near fuel tank. Has anyone done this mod ? How could it be done ? what kind of pump would be suitable ? I'm sure this could be a possible solution that doesnt entail much risk or loads of time and money.
