crispinchurch
234 -
10
crispinchurch last won the day on November 21 2017
crispinchurch had the most liked content!
About crispinchurch
- Birthday 08/26/1967
wiltshire
crispinchurch's Achievements
3.3 2006 Lpg Missfire On 1 And 3
crispinchurch replied to thedogss's question in Voyager 4th Generation (2001-2007)
i have just changed leads on mine a big difference spark plugs next on my list -
Head Light Bulb Types Facelift 2004 To 2007
crispinchurch replied to bignev's question in Voyager 4th Generation (2001-2007)
yeah treid the dip beam pointed more to floor -
Electrics
crispinchurch replied to christianmidlands's question in Voyager 4th Generation (2001-2007)
when you turn lights on the dash go dark next to light switch there wheel turn it up the dash light goes bright also inside lights come on when door open turn all way up inside lights on full time good idea to turn off in day -
i had too many people flashing me with hids in dip bean had to just have them in high beam think about extra earth strap and one from alt to battery + -
Spark Plugs Coming Loose
crispinchurch replied to crispinchurch's question in Voyager 4th Generation (2001-2007)
i got my gap from service manual thats there max so 1.3 would be spot on NGK is that what you use with lpg 3.3 ? -
if you got same rear shocks as mine they are adjustable by unbolt on end and screw in but make sure same number of turns on each side
hi has any one else had there spark plugs coming lose had two at rear and one at front and is spark plug gap really 1.5 mm its a bugger to get at rear ones i took the wiper box out and grill
Is My Radio Anplified
crispinchurch replied to Ldg2009's question in Voyager 3rd Generation (1996-2000)
open n/s sliding door see if you can pull the rear side panel away look for amp on floor near seat belt real -
s belt pullys ? GV do have a whine to them all three of mine have
Lpg Cutting Back To Petrol 3,000 + Revs
hi it happens anytime full or empty but more times when less than half tank the pressure which over was set at .75 to change back to petrol i changed this as i saw on instruction .5 this has improved it a lot i have tested the diafram many thanks for your help -
Dashcam Hardwire Issues
crispinchurch replied to ZombieRodeo's question in Voyager 4th Generation (2001-2007)
inside the car i take all hard wire items off the radio feed easy to get to -
crispinchurch posted a question in Voyager 4th Generation (2001-2007)
2003 lpg 3.3 runs fine on petrol a bit low on power switches over to lpg ok at 3,000 rev+ will cut back to petrol beeping switch back to lpg will run fin untill pushed to between 3,000 + and will cut back again filter on evaporator changed every 6000 any ideas please -
bignev reacted to an answer to a question: Leak Coolant Just Infront Rear Wheel
i have since put a longer pipe on and have it running a bigger bend when doing one do the other as well but have seen in Wilcos that they do a quick connect the correct size will say buy 16mm hose by 10m roll was a money saver as have hand the long metal heating pipe that are in front rust on bracket so ran new hose there as well -
local garage and local motor spares said chrysler only
